Linux PowerPC Server Software
Re: Linux PowerPC Server Software
Apache mod_authz_core part2:
Postfix with Dovecot including Sieve Pigeonhole via lda protocol:
xeno74 wrote: Wed Mar 18, 2020 10:08 am Fedora PPC64 with the SSH agent:
sshd_config
AllowUsers amigaone
This keyword can be followed by a list of user name patterns, separated by spaces. If specified, login is allowed only for user names that match one of the patterns. Only user names are valid; a numerical user ID is not recognized. By default, login is allowed for all users. If the pattern takes the form USER@HOST then USER and HOST are separately checked, restricting logins to particular users from particular hosts.
xeno74 wrote: Thu Jul 23, 2020 11:48 am Postfix with Dovecot including Sieve Pigeonhole via lda protocol:
anyof = or
 if anyof (
   header :contains "Subject" "SPAM",
   header :contains "Subject" "VIRUS"
   discard;
   stop;
allof = and
 if allof (
   header :contains "Subject" "Application",
   header :contains "Subject" "IT"
redirect "bewerbung@xenosoft.net";
Postfix with Dovecot including Sieve Pigeonhole via lda protocol part2 (vacation extension):
The ssh-agent is a program you may use together with OpenSSH or similar ssh programs. The ssh-agent provides a secure way of storing the passphrase of the private key. With an active ssh-agent, you don’t need a password for the private key if you connect to an other AmigaOne with the public key authentication.
xeno74 wrote: Wed Feb 12, 2020 4:04 pm openSUSE Tumbleweed PPC64 with iptables and Pure-FTPd in the NAT mode:
Passive mode: The FTP client opens the connection to the FTP server via the server port 21. The server tells the client the server port (1024 - 5000).
'-N': NAT mode. Force ACTIVE mode: The FTP client opens the connection to the FTP server via the server port 21 (FTPS: 990) and tells the server the port for data transfers. After that the server sends the client the files from port 20 (FTPS: 989) to this port.
xeno74 wrote: Wed Feb 12, 2020 3:33 pm openSUSE Tumbleweed PPC64 with iptables and Pure-FTPd:
vsftpd/TLS with iptables:
For the passive FTP mode:
iptables -t filter -I INPUT -p tcp --dport 1024: -j ACCEPT
