Updates do not work properly
Amiguy
Re: Updates do not work properly
Post by Amiguy »
@nbache
This is version 2.39 of AmiUpdate as you guessed. Looking more closely, I notice due AmiUpdate scans all the files on the local disk, then synchronizes them according to their source and according to their availability.
Thank you in any case for your return and a hello friendly from France ;)
Amiga 1200 2 MB Chip - Turbo 1230 32 MB Fast - CF 128 GB - Indivision MK3 - GOEX Drive - Roms & WB 3.1.4
Amiga Forever 7 Plus Edition which emulates AmigaOS4.1 FE Classic
AmigaOne X5000 2 GHz / 8 GB Ram - Radeon R7 250X - AmigaOS4.1 FE and Linux Fienix 3.0
No to laugh, not to lament, not to detest, but to understand.” - Baruch Spinoza
Yes, that sounds right. You can study more closely what it does by saving the log (go into the Updates prefs on the last tab and set a destination on disk for the log, and optionally also set the checkmark below it to get a more detailed log file).
And hello back to you :-).
Rigo
Post by Rigo »
Minuous wrote: Could you remove my apps from AmiUpdate please, they would be ....
Done
Simon
simulant
Post by simulant »
Hi can anyone please help me out with AmiUpdate.
I have version 2.43 installed on my X5000.
However I can't update to 2.47 or anything newer than I have. I've already set the update server to codebench but no updates are found.
I also went to the amiupdate website and to the Downloads section to try to manually download and update but I can't find any links to the newer versions.
Does anyone have a copy of anything after 2.43 they can send me or let me know what the link is to download the latest version please?
Thanks for any help
Rigo
Post by Rigo »
I have updated the full archive from the downloads page to 2.47.
See http://amiupdate.codebench.co.uk/index. ... =downloads for access to the archive.
Simon
simulant
Post by simulant »
Great thanks Simon :)
