Thank you very much Petrol and nbache for your help. After an amazing puzzle to return to normal operation, I can conclude the following facts.
According to the log file, I was able to connect to amiupdate.net at least once without problems with version 2.39 of 24/09/2015, which was never possible with version 2.45 of 20/05 / 2018. In addition, version 2.45 of the French catalog, from os4depot, is not valid.
No longer having the 2.41 file that Petrol is talking about, I'm happy with the English version, which works well. Nevertheless, I wonder what can explain that a change of version causes a connection error on amiupdate.net. Would it be a DNS problem? The IP of the site would have changed and an update would not have been made somewhere? Again, I'm happy for the moment of the connection with amiupdate.codebench.co.uk
In my opinion, there are certainly points of fragility to dig ...
Updates do not work properly
Re: Updates do not work properly
Amiga 1200 2 MB Chip - Turbo 1230 32 MB Fast - CF 128 GB - Indivision MK3 - GOEX Drive - Roms & WB 3.1.4
Amiga Forever 7 Plus Edition which emulates AmigaOS4.1 FE Classic
AmigaOne X5000 2 GHz / 8 GB Ram - Radeon R7 250X - AmigaOS4.1 FE and Linux Fienix 3.0
“No to laugh, not to lament, not to detest, but to understand.” - Baruch Spinoza
@Amiguy,
I can ensure you that the french catalog from Os4depot.net still works with AmiUpdate 2.45. I tested it again.
Be sure to copy the french catalogs on a fresh boot before launching AmiUpdate.
Regards,
Petrol
Regards,
Petrol
It doesn't have anything to do with the client version change, it's just something that started to happen around the same time.Amiguy wrote:Nevertheless, I wonder what can explain that a change of version causes a connection error on amiupdate.net.
Yes. Just use the server amiupdate.codebench.co.uk, the other one was/is redirected (when that worked) to the same actual server.Would it be a DNS problem?
@minuous
Well, I don't know who you approached to have your apps removed, but I've heard nothing.
The administrative email addresses for AmiUpdate are well publised, so you have no problem contacting someone that can help you.
If you have a problem, then feel free to email me here.
AmiUpdate is off-topic here, but I will be happy to show you the door if you really want to de-camp.
Simon
Simon
@Petrol
You are right Petrol. Version 2.41 of the french catalog on os4depot (and not 2.45, as I indicated by mistake) works correctly. I went directly from version 2.39 to version 2.45 and probably did not have version 2.41 initially. There must have been confusion between catalogs at some point. Excuse me.
@nbache
I see in the log of version 2.39, that we check the versions of all resources from the sites that host it. Is this operation still in progress?
@nbache
@Rigo:
Odd you didn't see it, I sent this email to the official mailing list at amiupdate@freelists.org last month:
Hello
Could you remove my apps from AmiUpdate please, they would be Africa,
AmiArcadia, CodeWar, Handy, MCE, Koules, Report+, Saga and Worm Wars. None of
them have supported AmiUpdate for years, they have their own updating
system. I don't (and can't) update their entries on the site anymore
in any case. No point listing obsolete versions of software.
James Jacobs
Amigan Software
Hello
James Jacobs
Amigan Software
Not that i want to be a pain, but why can't you update the entries anymore?Minuous wrote: I don't (and can't) update their entries on the site anymore in any case.
Maybe there's a bug on the site which will make it difficult for other users to update their entries in future too?
That would be nice to have fixed then...
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
@Raziel:
IIRC there used to be an "Edit" button which later disappeared. I reported the issue years ago, it was never investigated or fixed as apparently it is still OK for some users.
I just tried logging in and that didn't work either, maybe my account has already been removed. Although the apps are still listed.
Editing is done by displaying the entry, then typing your corrections into the relevant fields, and finally hitting Save.Minuous wrote:@Raziel:
Version 2.39 of what? AmiUpdate? Or the French catalogs? The releasenotes of AmiUpdate 2.39 say:Amiguy wrote:@nbache
AmiUpdate 2.39 (24.9.2015)
- Fixed support for X5020 and X5040.
- Added support for upcoming platform(s).
I'm not sure exactly what you are asking, but perhaps Rigo (author of AmiUpdate) can answer your question.
I'm just a user and Danish translator.
