Copy command memory leak
Castellen
Post by Castellen »
Hi OS3.1.4 team, thanks for all the hard work on delivering OS3.1.4 and the update.
Unfortunately 3.1.4 c:copy v45.3 and v45.4 in the 3.1.4.1 update both appear to have a memory leak. One of the jobs of this A4000T is a webserver, which calls the copy command for each webserver file request, which essentially performs a "copy filename console:" to send the requested file to the current TCP socket.
It's worked fine for 15+ years with the OS3.9 copy v40.1 and the updated v40.2 from Aminet. The problem with OS3.1.4 (and update) copy is that all 140MB of system memory is consumed in a day or so.
Checking memory lost overnight just now I see:
13.System:> avail
Type  Available    In-Use   Maximum   Largest
chip    1883472    197296   2080768   1854844
fast  101899600  44901040 146800640  79681788
total 103783072  45098336 148881408  79681788
13.System:> date
Tuesday 09-Jul-19 21:11:04
13.System:>
13.System:>
13.System:> avail
fast   70545552  76255088 146800640  55483644
total  72429024  76452384 148881408  55483644
13.System:> date
Wednesday 10-Jul-19 06:49:18
13.System:>
13.System:>
13.System:> version c:copy full
copy 45.4 (09/12/2018)
Works out to be about 31354048 bytes lost in the 460 webserver accesses logged over that time period, or approx. 68161 bytes every time the copy command is invoked.
Could you please have a look at this for the next round of maintenance? No hurry, as the workaround is to simply use the v40.2 copy command for now.
Anthony.
Gulliver
Re: Copy command memory leak
Post by Gulliver »
Hi Castellen,
The copy command had a problem where it did not release its copy buffer.
We have already managed to fix that issue.
Thank you for the report.
kolla
Post by kolla »
Gulliver wrote: Sun Jul 28, 2019 5:05 am We have already managed to fix that issue.
Will the fix be available anytime soon?
How about a binary patch on aminet while we wait for OS 3.2?
Castellen
Post by Castellen »
My workaround is to use an older copy command, which I'm still using today without problems with OS3.1.4.1:
copy 40.2 (09/07/2018)
This is the original copy v40.1 from WB3.1 patched to v40.2 using:
http://aminet.net/package/util/cli/CopyFix
