That's right, SLB was only for the SE/XE and Sams. The X-1000, X-5000 and A-1222 use "amigaboot".
Don, this is a puzzler. Would it be possible to try another drive in place of the SanDisk SSD?
It can't be the fact that it's an SSD since I have a Western Digital SSD in my X-5040, but there are SSDs and SSDs... It's just possible that U-Boot has a problem reading it, while AmigaOS hasn't.
AmigaOS only boots from install DVD
Re: AmigaOS only boots from install DVD
I, too, have a SSD disk in my X5000/020 (a Crucial MX500), and it works wonders.tonyw wrote:It can't be the fact that it's an SSD since I have a Western Digital SSD in my X-5040
The Rear Window blog
@donfirth
Does (your version of) UBoot support booting from NGS\00 partitions?
Just a thought.
OldFart
Just a thought.
OldFart
X5000, put back into storage since May 16, 2021 and eagerly awaiting awakening or so I hope
Dead MicroA1
A1200 in ElBox, c/w Blizzard '040 @ 50MHz + SCSI module, ZIV-board c/w (o.a.) cv64/3d + flickerdoubler + FastATA-ZIV + Lots of SCSI gear.
RaspBerry Pi 2B, 3B, 4B (4Gb) & 4B (8Gb) attached to Aten QubiC 4-port KVM
Dead MicroA1
It's amigaboot (in the SD card) that supports it, and the answer for an X-5000 is "yes, of course".
Thanks for the though.OldFart wrote:@donfirth
Just a thought.
OldFart
Apparently It does not.
Yesterday I found I couldn't even boot from CD so I looked into messages about the U-Boot.
The topic "Change uboot anim count" shows commands I just don't have.
It turns out my U-Boot is over 4 years old and only supports the Standard file system.
Any way trying to change amigabootmenu_animcycles and saveenv got my CD working again.
A fresh install with Standard File system with everything checked when formatting does the trick.
Thanks everyone for your input.
It's great to have a working computer again.
Now the question is how do I get the latest U-Boot to update my system.
When the animation starts, press the "M" key twice to get to the U-Boot prompt.
Then type "boota" and you should see the heading for amigaboot: something like "AmigaOS 4.x U-Boot Bootloader V53.xx".
Please tell me what version you have. I can't believe that it doesn't support NGFS volumes - support was built in long before any X-5000s were sold to the public.
I was in the Beta program - which was more confusing than anything else.tonyw wrote:When the animation starts, press the "M" key twice to get to the U-Boot prompt.
I am just getting back to the Amiga X5000 after letting it sit for some time.
When I preform the procedure you stated It boots up without the delay and I see a progress of # symbols.
Listing the loading modules.
I don't notice any relevant information.
That's because you let it run by itself. I want you to do the steps by hand, as I listed them.
When you type "boota", the first thing you will see is the heading at top of a clean new screen, then a list of bootable volumes (may be only one), and an arrow at the far left side, indicating which volume will supply the Kickstart modules.
If you hit the space bar quickly, the process will freeze so that you can read the top line. You can then hit the Enter key to continue the boot process.
V53.9tonyw wrote:That's because you let it run by itself. I want you to do the steps by hand, as I listed them.
The problem was amigaboot_quiet was set to Y
It took a while to figure out
setenv amigaboot_quiet N
saveenv
Yeah, that version is now four years old. I don't know what is being delivered with X-5000s these days, but my X-5040 had amigaboot V53.21 when delivered. I'm currently trying to get V53.27 ready for release.
Perhaps AmigaKit can give you a later SD card image?
