USB flash FAT32 and usb external NTFS drive
simulant
Re: USB flash FAT32 and usb external NTFS drive
Post by simulant »
nbache wrote:After the popup, can you try hitting Ctrl-Alt-M and see if you get the massstorage GUI up? What does it show, if anything?
Hi thanks for the suggestion but after it pops up and I hit ctrl alt + m only my hard drive partitions are shown...
usb.log shows this:
I: [21:52:09] hub.usbfd | HUB | Device found on port 4 of hub "".
I: [21:52:09] hub.usbfd | Hub port | Device at port 4 of hub "" is high-speed.
I: [21:52:09] USB stack | New Fkt | Fkt 0x53958a00 at level 4
I: [21:52:09] hub.usbfd | HUB | Device on hub port 4 successfully added.
I: [21:52:09] USB Fkt Init | Init Fkt | Fkt 0x53958a00 is {Vendor: 0x1058, Product: 0x0748, Class: 00.00}
I: [21:52:09] USB Fkt Init | Init Fkt | Fkt 0x53958a00 ("Western Digital","My Passport 0748","575837314336324C36343931") initialized
That sounds strange. The massstorage GUI should only show disks (massstorage devices) connected over USB. Your hard drive is not on USB, is it?
BTW, I happen to have a WD My Passport Ultra drive myself, but it's not quite the same as yours, mine has a product ID of 0x0820.
But I can't use that under AmigaOS either.
My popup says that the attached device is a multiclass device (or similar), which is probably the reason, I believe those are not supported (yet?).
Does your attachment popup say something similar?
My log goes on to say (after similar lines to yours):
I: [19:31:10]        MassStorage Device Task |                    Massstorage | Lun 0 has device type 0x00 (Direct access) and is not removable
I: [19:31:10]        MassStorage Device Task |                    Massstorage | Lun 1 has device type 0x0D (Unknown) and is not removable
E: [19:31:10]        MassStorage Device Task |                    Massstorage | Device type ignored
nbache wrote:That sounds strange. The massstorage GUI should only show disks (massstorage devices) connected over USB. Your hard drive is not on USB, is it?
The massstorage GUI on the current X5000 is different than all other OS4.x hardware in that respect. The last I heard the p5020sata.device isn't done and the X5000 disk system seems like some sort of a workaround to me.
Petrol
Post by Petrol »
It seems that the AmigaOS USB stack or another component can't mount disk partitions over 2TB currently, USB2 or 3 doesn't matter.
For your 1TB disk, if it is empty, try to format it on a OS other than Win10. Some users reports that some of there disks didn't work when they were formated with a win10 machines.
Regards,
simulant
Post by simulant »
Petrol wrote:Hi,
Regards,
Ah that explains it! I made a mistake with the drive size and on checking it looks like this drive is 3TB not 1TB!
Thanks at least now I know that it *shouldn't* work. Hopefully some bigger drive support will come along in a future update :)
Ah, yes, of course. Sorry, I had forgotten that simulant is on an X5000.
