Kernel 5.2
Re: Kernel 5.2
I think the problem with the Logitech wireless USB mouse is somewhere in the file a/drivers/hid/hid-logitech-dj.c.
Maybe this is the problem:
struct dj_device {
 	struct hid_device *hdev;
 	struct dj_receiver_dev *dj_receiver_dev;
-	u32 reports_supported;
+	u64 reports_supported;
 	u8 device_index;
Re: Kernel 5.2
Hi Ace,
I undid the changes in the file drivers/hid/hid-logitech-dj.c today. After that I created a new test kernel.
Download: uImage-hid2
Please test this kernel with your Logitech wireless USB mouse.
Just for info. The kernel developers rewrote the complete code for the Logitech wireless receivers.
They wrote: logitech-dj has historically been treating devices behind non-unifying receivers as generic devices, using the HID emulation in the receiver. That had several shortcomings (special keys handling, battery level monitoring, etc). The driver has been reworked to enumarate (and directly communicate with) the devices behind the receiver, to avoid the (too) generic HID implementation in the receiver itself. All the work done by Benjamin Tissoires and Hans de Goede.
This is the reason why your outputs of 'xinput list' are so different between the DRM11 and alpha2.
DRM11:
 ↳ Logitech USB Receiver id=7 [slave pointer (2)]
⎜ ↳ Logitech USB Receiver Consumer Control id=8 [slave pointer (2)]
alpha2:
⎜ ↳ Logitech M280/320/275 id=7 [slave pointer (2)]
Re: Kernel 5.2
HID2 boots to Firepro and Logitech mouse works fine.
allan@Amigaone:~$ xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Microsoft Wired Keyboard 600 Consumer Control id=7 [slave pointer (2)]
⎜ ↳ Microsoft Wired Keyboard 600 id=9 [slave pointer (2)]
⎜ ↳ Logitech USB Receiver Consumer Control id=10 [slave pointer (2)]
⎜ ↳ Logitech USB Receiver id=11 [slave pointer (2)]
⎜ ↳ SteelSeries SteelSeries Rival 100 Gaming Mouse id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Microsoft Wired Keyboard 600 id=6 [slave keyboard (3)]
↳ Microsoft Wired Keyboard 600 System Control id=8 [slave keyboard (3)]
allan@Amigaone:~$
Re: Kernel 5.2
acefnq wrote:Christian
allan@Amigaone:~$
Hi Ace,
Thanks a lot for testing! :-) Now, we definitely know, that the issue is somewhere in the file a/drivers/hid/hid-logitech-dj.c of the HID updates.
Re: Kernel 5.2
I released the alpha4 of kernel 5.2 for testing today. :-)
  • X1000: pata_of_platform-v2 patch for solving the issues with new CF cards connected to the onboard CompactFlash Card Slot
  • X1000: Disabling the kernel config options CONFIG_PATA_PCMCIA, CONFIG_PCMCIA, and CONFIG_ELECTRA_CF for the pata_of_platform-v2 patch
Download: linux-image-5.2-alpha4-X1000_X5000.tar.gz
Screenshot of Fienix PowerPC with the kernel 5.2-alpha4:
BTW, I created a new PowerPC cross compiling environment on ubuntu MATE 18.04.2 LTS x86_64 (GCC 7.4.0) today. This kernel has been compiled with this new cross compiling environment.
@SailorMH
@Ace
Please test the default kernel (uImage-5.2) with your two installed graphics cards and the additional test kernel (uImage-hid3) with your Logitech wireless USB mouse.
[1] I changed all lines with "u64 reports_supported;" to "u32 reports_supported;" in the file "a/drivers/hid/hid-logitech-dj.c".
Re: Kernel 5.2
Kernel 5.2 Alpha 4 running on the AmigaOne X5000 with the latest version of ArcticFox 27.9.17
Big picture http://www.skateman.nl/wp-content/uploa ... 202002.png
Re: Kernel 5.2
Skateman wrote:Kernel 5.2 Alpha 4 running on the AmigaOne X5000 with the latest version of ArcticFox 27.9.17
Many thanks for testing the alpha4! :-)
Re: Kernel 5.2
Both boot to Firepro but Logitech mouse does not work with either.
⎜ ↳ SteelSeries SteelSeries Rival 100 Gaming Mouse id=10 [slave pointer (2)]
⎜ ↳ Logitech Wireless Mouse PID:4040 id=11 [slave pointer (2)]
allan@Amigaone:~$
Re: Kernel 5.2
allan@Amigaone:~$
Hi Allan,
Thanks a lot for testing the kernels! :-)
Could you please file a bug report at https://bugzilla.kernel.org/buglist.cgi?component=Input Devices?
Re: Kernel 5.2
xeno74 wrote: Hi Allan,
Hi Allan,
Could you also please create the following xorg.conf (/etc/X11/xorg.conf) and reboot your X5000 with the stable kernel 5.1?
Section "Device"
        Identifier "ATI RV620 [FirePro 2260]"
        BusID   "PCI:5@4096:0:0"
EndSection
