Kernel 5.2
Re: Kernel 5.2
I used the final drm11 test kernel and the alpha of 5.2. Outputs below, logitech mouse works fine under drm11
DRM11:
allan@Amigaone:~$ xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech USB Receiver id=7 [slave pointer (2)]
⎜ ↳ Logitech USB Receiver Consumer Control id=8 [slave pointer (2)]
⎜ ↳ Microsoft Wired Keyboard 600 Consumer Control id=10 [slave pointer (2)]
⎜ ↳ Microsoft Wired Keyboard 600 id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Microsoft Wired Keyboard 600 id=9 [slave keyboard (3)]
↳ Microsoft Wired Keyboard 600 System Control id=11 [slave keyboard (3)]
allan@Amigaone:~$
5.2a
⎜ ↳ Logitech M280/320/275 id=7 [slave pointer (2)]
⎜ ↳ Microsoft Wired Keyboard 600 Consumer Control id=9 [slave pointer (2)]
⎜ ↳ Microsoft Wired Keyboard 600 id=11 [slave pointer (2)]
↳ Microsoft Wired Keyboard 600 id=8 [slave keyboard (3)]
↳ Microsoft Wired Keyboard 600 System Control id=10 [slave keyboard (3)]
allan@Amigaone:~$
Re: Kernel 5.2
Hi Ace,
Thanks for reporting the issue with your Logitech wireless USB mouse.
In my point of view the following updates are responsible for the issue.
Link: HID updates
I will try to compile a test kernel without these updates.
Re: Kernel 5.2
Alex Deucher and Michel Dänzer have responded because of our results with git bisecting.
Alex Deucher wrote:I'll send out a patch to revert the change.
Michel Dänzer wrote:Allan, please attach the /etc/X11/xorg.conf(.bak) file and the Xorg log files from the good and bad cases.
Link to the bug report: Bug 109345 - drm-next-2018-12-14 -Linux PPC
Re: Kernel 5.2
Logs submitted. DRM1-11 plus K5.2alpha. Great work.
Re: Kernel 5.2
acefnq wrote:Christian
Hi Ace,
Many thanks for submitting the logs. :-)
Have a nice weekend! :-)
Re: Kernel 5.2
The alpha3 of kernel 5.2 is available for testing. :-)
  • X1000: pata_of_platform-v2 patch for solving the issues with new CF cards connected to the onboard CompactFlash Card Slot
  • X1000: Disabling the kernel config options CONFIG_PATA_PCMCIA, CONFIG_PCMCIA, and CONFIG_ELECTRA_CF for the pata_of_platform-v2 patch
Download: linux-image-5.2-alpha3-X1000_X5000.tar.gz
Screenshot of Fienix PowerPC with the kernel 5.2-alpha3:
@SailorMH
@Ace
Please test the default kernel (uImage-5.2) with your two installed graphics cards and the additional test kernel (uImage-hid without the HID updates) with your Logitech wireless USB mouse.
Re: Kernel 5.2
Kernel 5.2 Alpha 3 on the AmigaOne X5000. Also connected a Wireless USB/Mouse Riitek MWK01. All working fine.
Big picture http://www.skateman.nl/wp-content/uploa ... 135112.png
Re: Kernel 5.2
uimage-5.2 boots to Firepro but wireless Logitech mouse does not work.
uimage-hid boots to Firepro and wireless Logitech mouse DOES work.
Cheers
Re: Kernel 5.2
Skateman wrote:Kernel 5.2 Alpha 3 on the AmigaOne X5000. Also connected a Wireless USB/Mouse Riitek MWK01. All working fine.
Thanks a lot for testing the alpha3! :-) It’s good to know that your wireless USB mouse/touchpad Riitek MWK01 works. Now, we know that only Logitech wireless USB mice are affected.
Have a great weekend! :-)
Re: Kernel 5.2
Cheers
Hi Ace,
Many thanks for testing the two alpha3 kernels! :-)
Fantastic! We know that the issue of your Logitech wireless USB mouse is somewhere in the HID updates. We have to figure out where we can report this issue.
