Kernel 5.2
Re: Kernel 5.2
sailorMH wrote:here it is!
works, cfcard visible, thanx
Hi SailorMH,
Thanks a lot for testing the RC4! :-)
Re: Kernel 5.2
I released the RC5 of kernel 5.2 for testing today.
  • X1000: pcmcia-v2 patch for solving the issues with new CF cards connected to the onboard CompactFlash Card Slot
  • X1000: Enabled the kernel config options CONFIG_PATA_PCMCIA, CONFIG_PCMCIA, and CONFIG_ELECTRA_CF for the pcmcia-v2 patch
Download: linux-image-5.2-rc5_X1000_X5000.tar.gz
@SailorMH
@Ace
Please test it with your two installed graphics cards and with your Logitech wireless USB mouse.
sailorMH
Re: Kernel 5.2
Post by sailorMH »
Thanks Christian,
works with cfcard.
Pegasos 2, Sam440ep-flex, AmigaOne X1000, Powebook G4, iMac G5, Powermac G5 Quad
MorphOS, AmigaOS, linux: MintPPC 11, Debian, Ubuntu ..., MacOS X
Re: Kernel 5.2
sailorMH wrote:Thanks Christian,
works with cfcard.
Hi SailorMH,
Many thanks for testing the RC5! :-)
Re: Kernel 5.2
I released the RC6 of kernel 5.2 for testing today.
Download: linux-image-5.2-rc6_X1000_X5000.tar.gz
Screenshot of a Samba AD-DC with kernel 5.2-rc6 and with Windows connected via VNC for using the RSAT tools (X5000):
@SailorMH
@Ace
Re: Kernel 5.2
Here is the RC7 of kernel 5.2 for the X5000 and X1000.
Download: linux-image-5.2-rc7_X1000_X5000.tar.gz
Screenshot of a Samba Active Directory Domain Controller 4.10.2 with the RC7 of kernel 5.2 on openSUSE Tumbleweed PPC64:
@SailorMH
@Allan (Ace)
Please test it with your two installed graphics cards and with your Logitech wireless USB mouse. Can you switch with CTRL-ALT-F1 (F2, F3, F4 etc) to another terminal after booting with the xorg.conf?
@Mechanic
Please test it with your JMB363 card.
mechanic
Re: Kernel 5.2
Post by mechanic »
Mechanic
Installed and working, including JMB363 card.
Thanks Christian.
Re: Kernel 5.2
mechanic wrote: Installed and working, including JMB363 card.
Thanks Christian.
Thank you for testing. :-)
Re: Kernel 5.2
The final kernel 5.2.0 is available. :-)
Download: linux-image-5.2-X1000_X5000.tar.gz
Thanks a lot to SailorMH and Mechanic for testing the kernels on the X1000 and many thanks to Skateman and Allan (acefnq) for testing the kernels on the X5000.
Screenshot of a Samba Active Directory Domain Controller 4.10.2 with the final kernel 5.2.0 on openSUSE Tumbleweed PPC64:
@SailorMH
Please test them with your CF cards.
@Allan (Ace)
Please test them with your two installed graphics cards and with your Logitech wireless USB mouse. Can you switch with CTRL-ALT-F1 (F2, F3, F4 etc) to another terminal after booting with the xorg.conf?
@Mechanic
Please test them with your JMB363 card.
Re: Kernel 5.2
I created a Tabor patch for the stable kernel 5.2 today. After that I compiled the stable kernel 5.2.11 for the Tabor board.
Download: linux-image-5.2.11-A1222.tar.gz
Could you also test it with all device tree blobs?
Downloads:
