Kernel 5.1
Re: Kernel 5.1
I created a patch for solving the VLC issue today.
vdso_datapage_vlc.patch:
diff -rupN a/arch/powerpc/include/asm/vdso_datapage.h b/arch/powerpc/include/asm/vdso_datapage.h
--- a/arch/powerpc/include/asm/vdso_datapage.h  2019-04-03 22:56:44.560645936 +0200
+++ b/arch/powerpc/include/asm/vdso_datapage.h  2019-04-04 02:20:09.479361827 +0200
@@ -82,10 +82,10 @@ struct vdso_data {
        __u32 icache_block_size;                /* L1 i-cache block size     */
        __u32 dcache_log_block_size;            /* L1 d-cache log block size */
        __u32 icache_log_block_size;            /* L1 i-cache log block size */
-       __u32 stamp_sec_fraction;               /* fractional seconds of stamp_xtime */
-       __s32 wtom_clock_nsec;                  /* Wall to monotonic clock nsec */
-       __s64 wtom_clock_sec;                   /* Wall to monotonic clock sec */
-       struct timespec stamp_xtime;            /* xtime as at tb_orig_stamp */
+       __s32 wtom_clock_sec;                   /* Wall to monotonic clock */
+       __s32 wtom_clock_nsec;
+       struct timespec stamp_xtime;    /* xtime as at tb_orig_stamp */
+       __u32 stamp_sec_fraction;       /* fractional seconds of stamp_xtime */
        __u32 syscall_map_64[SYSCALL_MAP_SIZE]; /* map of syscalls  */
        __u32 syscall_map_32[SYSCALL_MAP_SIZE]; /* map of syscalls */
Re: Kernel 5.1
FYI:
Christophe wrote: That change is part of the following commit:
https://git.kernel.org/pub/scm/linux/ke ... da32ecb60c
Just changing back the type of wtom_clock_sec to 32 bits without changing back the loading instruction is likely to give unexpected results on PPC64.
Are you using 32 bits or 64 bits powerpc ?
Can you please try below change:
diff --git a/arch/powerpc/kernel/vdso32/gettimeofday.S b/arch/powerpc/kernel/vdso32/gettimeofday.S
index 1e0bc5955a40..afd516b572f8 100644
--- a/arch/powerpc/kernel/vdso32/gettimeofday.S
+++ b/arch/powerpc/kernel/vdso32/gettimeofday.S
@@ -98,7 +98,7 @@ V_FUNCTION_BEGIN(__kernel_clock_gettime)
      * can be used, r7 contains NSEC_PER_SEC.
-    lwz    r5,WTOM_CLOCK_SEC(r9)
+    lwz    r5,(WTOM_CLOCK_SEC+LOPART)(r9)
     lwz    r6,WTOM_CLOCK_NSEC(r9)
     /* We now have our offset in r5,r6. We create a fake dependency
Re: Kernel 5.1
Christophe's patch works! VLC plays videos without any problems! :-)
Link to the test thread: VLC doesn't play videos anymore since the PowerPC fixes 5.1-3
Re: Kernel 5.1
Great news! :-)
The issue with the VLC in connection with the kernel 5.1 RC2 and higher is fixed!
Link to the patch: [PATCH] powerpc/vdso32: fix CLOCK_MONOTONIC on PPC64
Re: Kernel 5.1
I released the RC3-3 of kernel 5.1 today.
  • gettimeofday patch for solving the VLC issue (Thanks to Christophe Leroy)
  • Linux Git log
Download: linux-image-5.1-rc3-3-X1000_X5000.tar.gz
Screenshot of Fienix PowerPC with VLC 3.0.4 and with the RC3-3 of kernel 5.1:
tbreeden
Re: Kernel 5.1
Post by tbreeden »
HI Christian,
I get no problems booting and running 5.1-rc3-3, but I think I've something
wrong with my VLC. On attempting to play any downloaded sample video
VLC crashes with the following message
Fontconfig error: failed reading config file
Gtk-Message: 21:37:37.726: GtkDialog mapped without a transient parent. This is discouraged.
: CommandLine Error: Option 'help-list' registered more than once!
LLVM ERROR: inconsistency in registered CommandLine options
QObject::~QObject: Timers cannot be stopped from another thread
Segmentation fault (core dumped)
This happens with 5.1-rc3-2 and 5.1-rc3, and also 5.0.0.
I may have messed up an install of VLC much earlier.
Remove and re-install?
thanks,
Tom
Re: Kernel 5.1
Hi Tom,
Many thanks for testing the RC3-3. Please reinstall the VLC.
Have a nice weekend! :-)
sailorMH
Re: Kernel 5.1
Post by sailorMH »
kernel 5.3-rc3 works with fienix + southern island
Pegasos 2, Sam440ep-flex, AmigaOne X1000, Powebook G4, iMac G5, Powermac G5 Quad
MorphOS, AmigaOS, linux: MintPPC 11, Debian, Ubuntu ..., MacOS X
Re: Kernel 5.1
sailorMH wrote:kernel 5.3-rc3 works with fienix + southern island
Hi SailorMH,
Thanks a lot for testing the RC3 (RC3-3)! :-)
Re: Kernel 5.1
The VLC solution is on the way to the official kernel source code:
Michael Ellerman wrote: On 8. Apr 2019, at 15:03, Michael Ellerman <patch-notifications@ellerman.id.au> wrote:
On Thu, 2019-04-04 at 12:20:05 UTC, Christophe Leroy wrote:
Commit b5b4453e7912 ("powerpc/vdso64: Fix CLOCK_MONOTONIC
inconsistencies across Y2038") changed the type of wtom_clock_sec
to s64 on PPC64. Therefore, VDSO32 needs to read it with a 4 bytes
shift in order to retrieve the lower part of it.
Fixes: b5b4453e7912 ("powerpc/vdso64: Fix CLOCK_MONOTONIC inconsistencies across Y2038")
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Applied to powerpc fixes, thanks.
https://git.kernel.org/powerpc/c/dd9a99 ... 747e3366c5
