Yes, "NGF\00" is it, there is no other. Like older file systems, NGFS uses the first three bytes of the identifier for the type ("NGF"), and the last byte for the version on the disk (in other words, which file system version wrote the system instance on the disk volume. So far there is only the one version, "00", which has existed since 2012. One day I might clean up the data structures on the disk, making them all incompatible, then it will become "NGF\01".
You should find documentation in Documentation/NGFileSystem on an X5000 or Tabor system.
X5000
Re: X5000
Yes you have fixed it but AFAIK no updates have been released to the end users.tonyw wrote:I must protest Davey! All those applications work just fine on an NGFS partition. Were it not so, I would have fixed it.daveyw wrote: I recommend using at least 1 non-boot SFS/02 partition, as some applications don't like being run from NGFS (Odyssey, Amicygnix, I think Timberwolf).
So if the users are still using the same version of NGFS that was first shipped with the X5k i agree with Davey, use SFS for some applications (i remember that Odyssey needs it for sure).
Re: X5000
Have been using Odyssey on a NGFS partition for over a year now with no problems. The version on my system is 54.34 dated 09/11/2016, haven't a clue if that's the original or not.smf wrote:Yes you have fixed it but AFAIK no updates have been released to the end users.tonyw wrote:I must protest Davey! All those applications work just fine on an NGFS partition. Were it not so, I would have fixed it.daveyw wrote: I recommend using at least 1 non-boot SFS/02 partition, as some applications don't like being run from NGFS (Odyssey, Amicygnix, I think Timberwolf).
Re: X5000
http://forum.hyperion-entertainment.com ... =57&t=3826
http://forum.hyperion-entertainment.biz ... =10#p40884
Re: X5000
Thanks for reminding me about that fault. It was only with Timberwolf IIRC. There was never a problem with Odyssey (except for Odyssey's trick of exiting without closing its cookies file).
Re: X5000
Take a look at Windows/Passwords and see if "Remember" is flagged at the end.daveyw wrote:I have seen that Odyssey can't save or retrieve cached passwords anymore, although I don't know what would cause that.
I guess the "Password Saving" is built in, i didn't find a setting to turn it on or off.
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
Re: X5000
Hmmm. when I open Windows/Passwords, it's completely blank!Raziel wrote:Take a look at Windows/Passwords and see if "Remember" is flagged at the end.daveyw wrote:I have seen that Odyssey can't save or retrieve cached passwords anymore, although I don't know what would cause that.
Looks like something has gone pretty wrong. I still have Confs/passwords.db which hasn't been updated since 2015.
