OpenScreen & OpenScreenTags ... Why do they don't work ?
AmiDARK
Post by AmiDARK »
When I want to create a screen, I encounter issues ...
I am with a Sam440Flex.
I allocate bitmap :
	displayCore.mainBitMap = IGraphics->AllocBitMap( 640, 480, 32, BMF_INTERLEAVED, NULL );
Sometimes it does return a NULL Pointer.
Then if I create bitmap this way it don't work :
		struct NewScreen mainScreenDefine = {
				0, 0,
				640, 480,
				32,
				1, 0,
				HIRES,
				PUBLICSCREEN,
				NULL,
				displayCore.DefaultDisplayTitle,
				NULL,
		displayCore.mainScreen = IIntuition->OpenScreen( &mainScreenDefine );
If I try this :
		displayCore.mainScreen = IIntuition->OpenScreenTags( &mainScreenDefine,
				SA_Left, 0,       SA_Top, 0,
				SA_Width, 640,         SA_Height, 480,
				SA_Depth, 32,
				SA_DetailPen, 1, SA_BlockPen, 0,
				SA_Title, *displayCore.DefaultDisplayTitle,
				SA_BitMap, displayCore.mainBitMap,
				SA_Type, PUBLICSCREEN,
				SA_Draggable, TRUE,
				TAG_END	);
It don't work too .. .Even if I put NULL in place of &mainScreenDefine.
Can someone help me with a precise sample opening a Screen (without SDL or others stuff ... Only IGraphics & IIntuition) ?
Regards,
Re: OpenScreen & OpenScreenTags ... Why do they don't work ?
Post by thomasrapp »
Well. graphics.library is still backwards compatible with the classic Amiga native chip set.
This means that without specifying a special RTG pixel format you are limited to a depth of 8.
To get an RTG bitmap with a higher depth than 8 you have to specify a pixel format (for AllocBitMap) or a display ID (for OpenScreen) which supports that depth.
AmiDARK
Post by AmiDARK »
Thank you Thomasrapp for your answer.
I tried to use IGraphics->BestModeID to detect a 32bit compatible mode ID ... Without Success.
Screen only open if I set depth=8
void egeDisplay_OpenScreen( int Width, int Height, int Depth ){
	// 1. Check for BestModeID
	int BestModeID = IGraphics->BestModeID( BIDTAG_Depth, Depth,
			BIDTAG_DesiredWidth, Width, BIDTAG_DesiredHeight, Height,
			BIDTAG_NominalWidth , Width, BIDTAG_NominalHeight, Height,
			TAG_END);
	if ( BestModeID != 0 ){
		debugMessage( " BestModeID found\n" );
		// 2. Alloc Bitmap for screen
		displayCore.mainBitMap = IGraphics->AllocBitMap( Width,	Height, Depth,
					BMF_INTERLEAVED || BMF_CLEAR || BMF_DISPLAYABLE,
					NULL );
		if ( displayCore.mainBitMap != NULL ){
			debugMessage( " AllocBitMap succeess\n" );
			// 3. Create NewScreen structure to receive data needed to open the Screen
					0, 0, Width, Height, Depth,
					displayCore.DetailPen, displayCore.BlockPen,
					SPRITES,
					CUSTOMSCREEN ,
					NULL, /* Font Option */
					displayCore.DefaultDisplayTitle, /* Title of the Screen */
					NULL, /* Gadget Option */
			// 4. Open the new Screen using IIntuition.
					SA_DisplayID, BestModeID,
					TAG_END );
			if ( displayCore.mainScreen != NULL ){
				displayCore.setupScreen = &mainScreenDefine;
				debugMessage( "+ Screen opened successfully\n" );
			// Screen was not opened.
			}else{
				debugMessage( "- Screen was not correctly opened\n" );
		// Error message for faulty AllocBitmap
		}else{
			debugMessage( "- AllocBitMap did return a NULL Pointer value\n" );
	// Error message for faulty BestModeID
	}else{
		debugMessage( "- BestModeID did not return any useable ID\n" );
Should I Use P96 or CGX method for BestModeID ?
There are at least two errors in your code:
Firstly the mode ID is a 32 bit unsigned value. You should use uint32 as its type. Just "int" is too vague.
Secondly 0 is a valid mode ID. You should check the returned ID against INVALID_ID and not against 0.
Also I would drop the usage of struct NewScreen. This is a compatibility layer for very old OS versions (1.x). You should rather use OpenScreenTags with a NULL NewScreen pointer and supply only the required values as tags. You can omit all the default values, for example Width and Height. They are determined by the mode ID.
Find attached a working example.
Note that 32bit screens only work if the gfx card supports them. For example a classic Amiga with a PicassoIV won't run the program.
rtgscreen.zip
(1.4 KiB) Downloaded 920 times
AmiDARK
Post by AmiDARK »
Hello Thomasrapp.
Thank you for all your advices.
I will look your sample and update my code with your advices.
Regards,
AmiDARK
Post by AmiDARK »
Hello,
I did changes to my "OpenScreen" method using your advices and sample.
It gives this result :
BOOL egeDisplay_OpenScreen( int Width, int Height, int Depth ){
	BOOL success = FALSE;
	debugMessage( "CALL: egeDisplay_OpenScreen\n" );
	ULONG myBestModeID = IGraphics->BestModeID(
			BIDTAG_NominalWidth, Width, BIDTAG_NominalHeight, Height,
			BIDTAG_Depth, Depth, TAG_END );
	// 2.A If BestModeID success.
	if ( myBestModeID != INVALID_ID ){
		displayCore.mainScreen = IIntuition->OpenScreenTags( NULL,
				SA_Title, displayCore.DefaultDisplayTitle,
				SA_DisplayID, myBestModeID,
				SA_Depth, displayCore.Depth,
				// SA_Pens, displayCore.DetailPen, pointer to a pens array finished by {0} ... Ex : static const UWORD pens[] = {~0};
				SA_ErrorCode, &displayCore.Error,
				TAG_END );
			success = TRUE;
		}else{
			printf( "error code = %lu\n", displayCore.Error );
	}else{
		debugMessage( "- BestModeID did return INVALID_ID\n" );
	return success;
But I always get the message "BestModeID did return INVALID_ID"..
I am on Sam440EP with Amiga OS 4.1 Finale Edition.
The resolutions I use is defined in my prefs.
What screen size and depth are you requesting?
Edit: I see from the first post that your trying for 640x480x32 Well that should be fine, ofcourse. Try verifying that you really are passing those values by extending your debug output.
Check in the screenmode prefs that those values are in fact available. If you asked for 32bit mode and you only have 16bit modes available for some reason then it might fail.
broadblues wrote:What screen size and depth are you requesting?
I wrote a short test program that calls BestModeIDTags() and prints the result. It fails like AmiDark's code. I also compiled the example program that thomasrapp attached to his post and it fails with this error: "cannot get proper screen mode for 640 x 480 x 32". I also tried getting other modes like '1024x768x32' which also fail. All the modes I tested are shown in my Prefs/Screenmode window.
AmiDARK
Post by AmiDARK »
@broadblues : 640x480x32 is the requested mode.
I have from 640x480 to 1280x1024 screen modes availables in my prefs with 8, 16 and 32 bits modes.
I tried fixed values (entering directly the 640, 480 and 32 values in the methods parameters ... same result.
@Xenic : Happy to see that I'm not alone.
In previous tests (few days sooner), the BestModeID did randomly gives INVALID_ID (from one run to another) when trying 8 bits display... without explanations.
AmiDARK wrote:I have from 640x480 to 1280x1024 screen modes availables in my prefs with 8, 16 and 32 bits modes.
Well, no, actually you don't. BGRA32 ias the name of the pixel format, not the depth.
Attached is a program which lists all available screen modes. As you can see all the 32 bit modes have a depth of 24. Only uaegfx adds its modes with a depth of 32, which from now on should be considered a bug.
The alpha channel is ignored anyway, so 24 is the correct depth from that point of view.
modelist.lha
(3.06 KiB) Downloaded 593 times
