Arctic Fox 27.9.12 (Firefox 63.0) a fork of Pale Moon
caseycullen
Post by caseycullen »
caseycullen wrote:
xeno74 wrote:SpiderWeb 2.1.0 is now available. This release sits on top of the current UXP-28.6.1 code base.
Download
Christian / All,
Could you please try installing Greasemonkey 3.10 with SpiderWeb? It seems to install for me, but scripts like ViewTube will not install. When I try to do so the dialog window appears, but clicking "Install" does nothing.
-Casey
Update: Matt responded "Yeah i havent found a 100% working one yet. Take a look at this post for a work-a-round for now. https://forums.macrumors.com/threads/pa ... t-27624889"
I will be putting together a deb package for Fienix with Greasemonkey 3.10, ViewTube, and ViewTube+ that will automatically install the scripts into the right place.
-Casey
caseycullen wrote: Update: Matt responded "Yeah i havent found a 100% working one yet. Take a look at this post for a work-a-round for now. https://forums.macrumors.com/threads/pa ... t-27624889"
-Casey
Good to know! I am looking forward to getting your modified SpiderWeb version!
caseycullen
Good News: Greasemonkey and ViewTube work with Spiderweb.
Bad News: I can't package the ViewTube scripts.
Workaround: If you don't already have it installed, install SpiderWeb 2.1.0-2fienix, which will also install Greasemonkey 3.10.
Download and extract this folder - "gm_scripts".
Open to your home folder and show hidden files (View > Show Hidden Files).
Open .wicknix > spiderweb, and open the folder ending in .default.
Copy the extracted "gm_scripts" folder you downloaded into this folder.
Make sure Greasemonkey is enabled (open SpiderWeb; Tools > Add-ons Manager > Extensions).
-Casey
caseycullen wrote:Good News: Greasemonkey and ViewTube work with Spiderweb.
-Casey
Hi Casey,
Thanks a lot for your work! :-) I successfully installed SpiderWeb 2.1.0 via your repository on Fienix today. Unfortunately it installed Greasemonkey 3.8. I had to download and install Greasemonkey 3.10 from the SpiderWeb addons site. After that I downloaded and extracted your "gm_scripts" and copied them to the folder .wicknix/spiderweb. Now I can watch YouTube videos with SpiderWeb! :-)
caseycullen
xeno74 wrote: Hi Casey,
Glad you got it to work! I'll have to look at why the repository installed 2.8 instead of 3.10...
Thanks for testing it out!
-Casey
Wicknix wrote: Mac 32-bit and 64-bit builds of 27.9.18 are now available. PPC 32-bit Linux version also now available.
Change log: https://github.com/wicknix/Arctic-Fox/releases/tag/27.9.18
Download: arcticfox-27.9.18.linux-powerpc.tar.bz2
caseycullen
I just released Arctic Fox 27.9.18 in the Fienix Software Repository. See Fienix News.
Also, an issue with the Greasemonkey package has been fixed. Please test installing/reinstalling Greasemonkey from the repository.
Let me know if you have any issues.
Thanks!
Casey
caseycullen wrote:I just released Arctic Fox 27.9.18 in the Fienix Software Repository. See Fienix News.
Thanks!
Casey
Hi Casey,
Many thanks for Arctic Fox 27.9.18. I successfully installed it today and it works. I updated Greasemonkey as well and it also works. :-)
Screenshot:
Could you please add the NetworkManager Applet and the firmware-misc-nonfree package to your repository?
You need the following packages:
  • firmware-misc-nonfree_20190717-2_all.deb
  • network-manager-gnome_1.8.22-2_powerpc.deb
  • libnma0_1.8.22-2_powerpc.deb
Additionally please add /sbin to the PATH variable (export PATH=$PATH:/sbin).
Here is Arctic Fox 27.9.18 for old Linux PowerPC distributions like Ubuntu 10.04 or higher.
Download: arcticfox-27.9.18-ubuntu10.04-powerpc.tar.bz2
For Ubuntu 10.04: You need to install the GCC 4.8 and the libatomic1 via the repository 'ppa:ubuntu-toolchain-r/test'.
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update; sudo apt-get install gcc-4.8 g++-4.8
For Ubuntu 12.04: You need the libatomic1 package. Download: libatomic-ubuntu12.04-powerpc.tar.bz2
Please copy the file 'libatomic.so.1' to '/usr/lib/powerpc-linux-gnu/' with the following command:
sudo cp libatomic.so.1 /usr/lib/powerpc-linux-gnu/
Screenshots of Arctic Fox 27.9.18 for old Linux distributions:
Arctic Fox 27.9.18 is available for Linux 64-bit PowerPC.
Download: arcticfox-27.9.18.linux-powerpc64.tar.bz2
I successfully tested it on Fedora 27 Server PPC64 and on openSUSE Tumbleweed 20190722 PPC64 today.
Screenshots:
Image Image
