Arctic Fox 27.9.12 (Firefox 63.0) a fork of Pale Moon
Hi Peter,
Do you have issues with Xorg? Casey has some issues with Xorg on Debian PPC64.
Link to the thread
Do you use a xorg.conf?
Hi Christian.
I now have a debian 64 up and running.
Yes i use a xorg.conf file.
Peter
musa wrote: Hi Christian.
Peter
Hi Peter,
Many thanks for testing Debian PPC64 (Linux Mint) and thanks a lot for the screenshot! :-)
I will report Casey about your test result.
Wicknix has released Arctic Fox 27.9.19. :-)
Change Log
Downloads:
Support thread: forums.macrumors.com
For Ubuntu 10.04: You need to install the GCC 4.8 and the libatomic1 via the repository 'ppa:ubuntu-toolchain-r/test'.
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update; sudo apt-get install gcc-4.8 g++-4.8
For Ubuntu 12.04: You need the libatomic1 package. Download: libatomic-ubuntu12.04-powerpc.tar.bz2
Please copy the file 'libatomic.so.1' to '/usr/lib/powerpc-linux-gnu/' with the following command:
sudo cp libatomic.so.1 /usr/lib/powerpc-linux-gnu/
Screenshot of the new Arctic Fox 27.9.19 on Ubuntu 10.04.4 LTS Lucid PowerPC (A-EON AmigaOne X5000/40):
Screenshot of the new Arctic Fox 27.9.19 on Ubuntu 10.04.4 LTS Lucid PowerPC (Apple PowerMac G4):
Screenshot of the new Arctic Fox 27.9.19 on the Ubuntu 10.04.0 Live DVD PowerPC (Apple PowerMac G3):
Happy Holidays AND Happy New Year! :-)
Here is Arctic Fox 27.9.19 for Linux PowerPC64!
Download: arcticfox-27.9.19.linux-powerpc64.tar.bz2
Enjoy the next days!
.mozconfig for PPC64:
# This Source Code Form is subject to the terms of the Mozilla Public
# License, v. 2.0. If a copy of the MPL was not distributed with this
# file, You can obtain one at http://mozilla.org/MPL/2.0/.
export CC="gcc-6.4 -flax-vector-conversions -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export CXX="g++-6.4 -flax-vector-conversions -fpermissive -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export LDFLAGS="-latomic"
mk_add_options MOZ_OBJDIR=@TOPSRCDIR@/obj-ff-dbg
ac_add_options --enable-mozril-geoloc
ac_add_options --disable-parental-controls
ac_add_options --enable-release
ac_add_options --disable-eme
ac_add_options --enable-dbus
ac_add_options --disable-gio
ac_add_options --enable-strip
ac_add_options --enable-install-strip
ac_add_options --enable-application=browser
ac_add_options --with-branding=browser/branding/arcticfox
ac_add_options --enable-optimize="-O2 -fno-schedule-insns2 -fno-lifetime-dse -fno-delete-null-pointer-checks"
Wicknix has released Arctic Fox 27.10.1. :-)
Change Log
Downloads:
The 64-bit PowerPC version of Arctic Fox 27.10.1 is available.
Download: arcticfox-27.10.1.linux-powerpc64.tar.bz2
FYI: Arctic Fox doesn’t work on Debian 7 64-bit.
I tried to compile the new alpha version of Arctic Fox 27.10.2 on Ubuntu 10.04.4 PowerPC today but without any success. Any ideas? The version 27.10.1 compiles without any problems on Ubuntu 10.04.4 PowerPC.
I solved the issue. I copied the src directory to my AmigaOne X1000. After that I was able to link the Arctic Fox 27.10.2a binary. I am very happy. The problem was my virtual PowerMac. It doesn't have enough power to link the new Arctic Fox binary.
