Kernel 5.0
Re: Kernel 4.21
Next step: 7ebc44c535f6bd726d553756d38b137acc718443 (powerpc/dma: remove max_direct_dma_addr)
git checkout 7ebc44c535f6bd726d553756d38b137acc718443
Link to the Git: http://git.infradead.org/users/hch/misc.git/shortlog/refs/heads/powerpc-dma.5
OK, the PASEMI onboard ethernet works and the X5000 boots.
Re: Kernel 4.21
Next step: e15cd8173ef85e9cc3e2a9c7cc2982f5c1355615 (powerpc/dma: fix an off-by-one in dma_capable)
git checkout e15cd8173ef85e9cc3e2a9c7cc2982f5c1355615
The PASEMI onboard ethernet also works with this commit and the X5000 boots without any problems.
Re: Kernel 4.21
Next step: 602307b034734ce77a05da4b99333a2eaf6b6482 (powerpc/fsl_pci: simplify fsl_pci_dma_set_mask)
git checkout 602307b034734ce77a05da4b99333a2eaf6b6482
The PASEMI onboard ethernet works and the X5000 boots.
Re: Kernel 4.21
Next step: c1bfcad4b0cf38ce5b00f7ad880d3a13484c123a (dma-mapping, powerpc: simplify the arch dma_set_mask override)
git checkout c1bfcad4b0cf38ce5b00f7ad880d3a13484c123a
Result: No problems with the PASEMI onboard ethernet and with booting the X5000 (P5020 board).
Re: Kernel 4.21
Next step: 64ecd2c160bbef31465c4d34efc0f076a2aad4df (powerpc/dma: use phys_to_dma instead of get_dma_offset)
git checkout 64ecd2c160bbef31465c4d34efc0f076a2aad4df
The P5020 board boots and the PASEMI onboard ethernet works.
Re: Kernel 4.21
Next step: 977706f9755d2d697aa6f45b4f9f0e07516efeda (powerpc/dma: remove dma_nommu_mmap_coherent)
git checkout 977706f9755d2d697aa6f45b4f9f0e07516efeda
Re: Kernel 4.21
Next step: 7decbcfc656805603ab97206b3f816f26cd2cf7d (powerpc/dma: use generic direct and swiotlb ops)
git checkout 7decbcfc656805603ab97206b3f816f26cd2cf7d
We have the bad commit! :-) The PASEMI onboard ethernet doesn't work with this commit anymore.
Error messages:
[  367.627623] pci 0000:00:1a.0: dma_direct_map_page: overflow 0x000000026bcb5002+110 of device mask ffffffff bus mask 0
[  367.627631] pci 0000:00:1a.0: dma_direct_map_page: overflow 0x000000026bcb5002+110 of device mask ffffffff bus mask 0
[  367.627639] pci 0000:00:1a.0: dma_direct_map_page: overflow 0x000000026bcb5002+110 of device mask ffffffff bus mask 0
[  367.627647] pci 0000:00:1a.0: dma_direct_map_page: overflow 0x000000026bcb5002+110 of device mask ffffffff bus mask 0
pci 0000:00:1a.0 = 00:1a.0 DMA controller: PA Semi, Inc PWRficient DMA Controller (rev 12)
X5000 (P5020 board): U-Boot loads the kernel and the dtb file. Then the kernel starts but it doesn't find any hard disks (partitions). That means this is also the bad commit for the P5020 board.
Re: Kernel 4.21
xeno74 wrote:Next step: 7decbcfc656805603ab97206b3f816f26cd2cf7d (powerpc/dma: use generic direct and swiotlb ops)
Error messages:
Way to go ! :-)
While busy... would be nice if the onboard X5000 ethernet adapter could be kernel fixed as well !
Re: Kernel 4.21
FYI
Christoph Hellwig wrote: Thanks for bisecting. I've spent some time going over the conversion
but can't really pinpoint it. I have three little patches that switch
parts of the code to the generic version. This is on top of the
last good commmit (977706f9755d2d697aa6f45b4f9f0e07516efeda).
Can you check with whіch one things stop working?
From 83a4b87de6bc6a75b500c9959de88e2157fbcd7c Mon Sep 17 00:00:00 2001
Date: Wed, 12 Dec 2018 15:07:49 +0100
Subject: get_required_mask
 arch/powerpc/kernel/dma-iommu.c | 2 +-
diff --git a/arch/powerpc/kernel/dma-iommu.c b/arch/powerpc/kernel/dma-iommu.c
index 5b15e53ee43d..2e682004959f 100644
--- a/arch/powerpc/kernel/dma-iommu.c
+++ b/arch/powerpc/kernel/dma-iommu.c
@@ -152,7 +152,7 @@ u64 dma_iommu_get_required_mask(struct device *dev)
 		return 0;
 	if (dev_is_pci(dev)) {
-		u64 bypass_mask = dma_nommu_get_required_mask(dev);
+		u64 bypass_mask = dma_direct_get_required_mask(dev);
 		if (dma_iommu_bypass_supported(dev, bypass_mask))
 			return bypass_mask;
2.19.2
From c2579a3619575397929781a14895966cbc1d217b Mon Sep 17 00:00:00 2001
Date: Wed, 12 Dec 2018 15:08:52 +0100
Subject: swiotlb dma_supported
 arch/powerpc/kernel/dma-swiotlb.c | 2 +-
diff --git a/arch/powerpc/kernel/dma-swiotlb.c b/arch/powerpc/kernel/dma-swiotlb.c
index aa11625c6691..52ee531c1a0d 100644
--- a/arch/powerpc/kernel/dma-swiotlb.c
+++ b/arch/powerpc/kernel/dma-swiotlb.c
@@ -36,7 +36,7 @@ const struct dma_map_ops powerpc_swiotlb_dma_ops = {
 	.free = __dma_nommu_free_coherent,
 	.map_sg = swiotlb_map_sg_attrs,
 	.unmap_sg = swiotlb_unmap_sg_attrs,
-	.dma_supported = swiotlb_dma_supported,
+	.dma_supported = dma_direct_supported,
 	.map_page = swiotlb_map_page,
 	.unmap_page = swiotlb_unmap_page,
 	.sync_single_for_cpu = swiotlb_sync_single_for_cpu,
2.19.2
From 0105db9e6d8d031b4295116630fd0318fd146737 Mon Sep 17 00:00:00 2001
Date: Wed, 12 Dec 2018 15:10:36 +0100
Subject: nommu dma_supported
 arch/powerpc/kernel/dma.c | 2 +-
diff --git a/arch/powerpc/kernel/dma.c b/arch/powerpc/kernel/dma.c
index a6590aa77181..f53d11d35230 100644
--- a/arch/powerpc/kernel/dma.c
+++ b/arch/powerpc/kernel/dma.c
@@ -179,7 +179,7 @@ const struct dma_map_ops dma_nommu_ops = {
 	.alloc				= __dma_nommu_alloc_coherent,
 	.map_sg				= dma_nommu_map_sg,
-	.dma_supported			= dma_nommu_dma_supported,
 	.map_page			= dma_nommu_map_page,
 #ifdef CONFIG_NOT_COHERENT_CACHE
 	.sync_single_for_cpu 		= dma_nommu_sync_single,
2.19.2
From 4c5dd4d4a4b4e63be722fd29ada896c5962072b8 Mon Sep 17 00:00:00 2001
Date: Wed, 12 Dec 2018 15:11:38 +0100
Subject: alloc/free
 arch/powerpc/kernel/dma.c | 5 +++++
 1 file changed, 5 insertions(+)
index f53d11d35230..d3db6d879559 100644
@@ -176,8 +176,13 @@ static inline void dma_nommu_sync_single(struct device *dev,
 #endif
+#ifdef CONFIG_NOT_COHERENT_CACHE
+#else
+	.alloc				= dma_direct_alloc,
+	.free				= dma_direct_free,
+#endif
2.19.2
Re: Kernel 4.21
Today I tried the first patch with the last good commit (977706f9755d2d697aa6f45b4f9f0e07516efeda).
0001-get_required_mask.patch
 		return 0;
 			return bypass_mask;
2.19.2
Unfortunately this patch is already included in the last good commit (977706f9755d2d697aa6f45b4f9f0e07516efeda).
