Spencer 1.0 and audio
ssolie
Post by ssolie »
I just installed Spencer on my X5000 and it guru'd on first try. No happiness. I sent a bug report to the authors.
Then I took a chance and tried installing an audio card.
After the audio card was installed then Spencer worked without issue.
Great little game by the way. Easily worth the moola.
FYI
daveyw
Re: Spencer 1.0 and audio
Post by daveyw »
ssolie wrote: Then I took a chance and tried installing an audio card.
You don't have a sound card installed in your X5000 as a standard?
So u could say that having a Soundcard is a Spencer 1.0 requirement :-)
salass00
Post by salass00 »
Having the VOID driver (equivalent of >NIL: for AHI basically) available would probably be a good idea for systems with no usable sound card installed. Unfortunately it is not included with the OS yet IIRC.
ssolie
Post by ssolie »
Skateman wrote:So u could say that having a Soundcard is a Spencer 1.0 requirement :-)
Yeppers. Not a big issue for most I'm sure.
Anyway, the bug has been fixed since I posted and I assume and updated Spencer will be made available to all.
seventhwonder
Post by seventhwonder »
@ssolie
Game also doesn't work on A1222. Maybe that was the reason ?
AmigaOS4 Beta-Tester
