Newlib bug report
rwo
Newlib bug report
Post by rwo »
Okay .. I found the energy to code. and it revealed a buggie in Newlib's waitselect()
Basicly if I set some Amiga Signaled to break on like CTRL+C.. I want the break bits in Mask.. but its simple returning Zero
newlib.library 53.36 (17/09-2016) (A1222 version)
#include <proto/dos.h>
#include <proto/exec.h>
#include <proto/socket.h>
#include <stdio.h>
#include <string.h>
int main( int argc UNUSED, char **argv UNUSED )
unsigned int mask;
fd_set read;
int s;
	signal( SIGINT, SIG_IGN );
	s = socket( AF_INET, SOCK_STREAM, 0 );
	FD_ZERO( &read );
	FD_SET( s, &read );
	mask = SIGBREAKF_CTRL_C;
	int32 val = waitselect( s + 1, & read, NULL, NULL, NULL, & mask );
	printf( "Mask : %08lx, Val : %ld\n", mask, val );
	return( 0 );
Re: Newlib bug report
rwo wrote:Okay .. I found the energy to code. and it revealed a buggie in Newlib's waitselect()
I could be wrong, but I suspect that Newlib's waitselect() is just a stub for the bsdsocket.library WaitSelect() function. If that's the case then this quote from the bsdsocket autodoc might explain your problem:
  • Reception of the standard break signal (e.g. via Ctrl+C) will cause
    WaitSelect() to return -1 and set the error code to EINTR.
    Additionally, the standard break signal will be posted. This means
    that the signal will still be set when WaitSelect() returns, and
    can be tested. If -1 is returned, the contents of the user signal
    mask pointed to by the 'signals' parameter will be undefined.
You could test for Ctrl+C with SetSignal() and possibly clear it if set.
salass00
Post by salass00 »
xenic wrote: You could test for Ctrl+C with SetSignal() and possibly clear it if set.
For common use cases like the above CheckSignal() is much simpler to use.
The following code checks for set CTRL-C signal and clears it:
if (IDOS->CheckSignal(SIGBREAKF_CTRL_C)) {
    /* CTRL-C signal received */
and is equivalent to the following using IExec->SetSignal():
if (IExec->SetSignal(0, SIGBREAKF_CTRL_C) & SIGBREAKF_CTRL_C) {
I've seen a problem with this myself. My notes say (and this is all the information I have):
WaitSelect() from bsdsocket.library returns -1 if the task was
			 * signalled with a Ctrl-C.  waitselect() from newlib.library does not.
			 * Adding the Ctrl-C signal to our user signal mask causes a Ctrl-C to
			 * occur sporadically.  Otherwise we never get a -1 except on error.
