Set up the button "Start Linux"
You can set up the button "Start Linux" in the AmigaONE Early Startup Control of the AmigaOne X5000 with the following commands:
X5000> setenv linuxboot 'setenv bootargs root=/dev/sda2 ; load sata 0:1 1000000 uImage-4.18 ; load sata 0:1 2000000 cyrus.dtb ; bootm 1000000 - 2000000'
X5000> saveenv
Re: Set up the button "Start Linux"
Today I successfully reconfigured the variable linuxboot for the button "Start Linux".
New value:
X5000> setenv linuxboot 'setenv bootargs root=/dev/sda2 ; load sata 1:1 1000000 uImage-5.8 ; load sata 1:1 2000000 cyrus-p5040.dtb ; bootm 1000000 - 2000000'
X5000> saveenv
Tijatjj
Post by Tijatjj »
Ok thank you
