Hard drive format
Re: Hard drive format
Thanks Niels. That looks very helpful. Now if I remembered the boot device variable as I've heard it before it would have saved me editing Kicklayouts. Always the way, after the fact.
When you say "startup wasn't working because it ignored my mouse buttons!", what do you mean?Hypex wrote:I got caught in all this when I needed to transfer my XE HDD to my X1000 to transfer all my files. Long story short. The bootloader found my XE AmigaOS volumes and tried to boot off it! I didn't notice at first because all the labels were named "Amiga OS 4.1" something but knew something was wrong when every selection I tried was crashing. Then I saw my XE volumes were first in the boot list!
So then I picked what it would usually boot from but found it was still booting from the XE Workbench! Argh! It got worse as the early startup wasn't working because it ignored my mouse buttons! Double argh! This hasn't happened before. I'd gotten used to AmigaBoot being able to boot off the same volume as picked in the menu but here it was acting like SLB by loading Kickstart off one volume and booting Workbench off another. Very annoying "feature". I think BootDevice should be a requirement of installing a new Kicklayout.
I decided I would need to boot the CD. But I managed to load Kickstart off HDD by the time it was in the drive and then it booted off the CD. This was good as it was faster. And it had priority above the rest. So it booted the CD. My point here is that it is strange if the CD doesn't boot as in a normal setup the CD will always boot above all others. It's usually only when the HDD pri is set above 0 to values like 5 or 10 that this problem arises. And with a newly formatted HDD with standard boot volume settings this should never happen.![]()
I then disabled the bootable flag but AmigaBoot still picked the Kicklayout. According to the docs it shouldn't do that so will look into that.![]()
It only got worse from here when I decided to shrink my BOOT volume and copied amigaboot.of over only to find CFE couldn't find it any more. And when I tried to boot CD it couldn't find the CD in the drive.But that's another story.
Steff I mean in the Amiga early startup menu where you can pick what AmigaDOS volume to boot from and other stuff. It should come up when you hold down both mouse buttons. Or press scroll lock for Help.
There is a bug where it ignores the mouse buttons. And because of my keyboard (Mac) I can't press scroll lock if it has it anywhere. So I get stuck.
I am still experiencing huge problems here. I followed this:
1. While the Boing Ball is spinning (before it gets shot at), press any key on the keyboard. You should then see the "AmigaOne Early Startup Control" screen.
2. Press "M" to get to the command line.
3. Type "printenv" (no quotes) and <Enter>. You will see a list of all the known variables held in memory on the SD card. I bet that there is NOT one that says "bootable_only".
4. Type "setenv bootable_only 1" (no quotes) and <Enter>. That will ensure that the system does not try to boot from an invalid partition.
5. Type "saveenv" and <Enter> to save the new variable. If you like, you can type "printenv" again to see the saved result.
6. Type "boota" to reboot.
Only to be left with
Can someone please tell me how i can reverse this so i can boot from USB drive ??? and have Workbench !!
Thanks in advance.
Thanks in advance.
I have solved the problem by changing "setenv bootable_only 1" to "setenv bootable_only 4" then rebooted the USB.
The only settings that work for "bootable_only" are "y", "Y", and "1". Everything else is taken as "No".
So setting it to "4" is the same as not setting it at all.
