Kernel 4.18
Re: Kernel 4.18
acefnq wrote: Done
Working fine. Thanks as usual for your ongoing hard work.
Allan
Hi Allan,
Re: Kernel 4.18
Running on my X5000! No probs..
Re: Kernel 4.18
Skateman wrote:Running on my X5000! No probs..
Thanks a lot for testing the RC6! :-)
Re: Kernel 4.18
Re: Kernel 4.18
RC-7 is running fine on my X5000! :-)
Re: Kernel 4.18
Many thanks for testing the RC7!!!!
Re: Kernel 4.18
Re: Kernel 4.18
RC8 Up and running on my X5000 :-)
Wifi connected using a Zyxel USB adapter. the AG-225H
Re: Kernel 4.18
Skateman wrote:RC8 Up and running on my X5000 :-)
You're fast! Many thanks!!!!! :-)
Skateman wrote: Wifi connected using a Zyxel USB adapter. the AG-225H
It's good to know that Wifi works with your USB adapter. Very interesting! Thank you!
Re: Kernel 4.18
Here is the final kernel 4.18 for the X5000, X1000, and for virtual e5500 QEMU machines.
Download: vmlinux-4.18-AmigaOne_X1000_X5000.tar.gz
Many thanks to all for testing the alphas and release candidates! :-)
