AmigaOne X5000 - FreeBSD Only
Re: AmigaOne X5000 - FreeBSD Only
Yep
chmeee
Post by chmeee »
Skateman wrote:Like mentioned in the FreeBSD readme i have adjusted the setenv loadaddr from 1000000 to 0x3ffffc0
Ubuntu booted and all functional. The DPAA network issues still appear. To bad..
I will revert the the setenv loadaddr 0x3ffffc0 to 1000000
It was worth the try :-)
Did it boot at all, and fail to attach the ethernet controller? I've been running FreeBSD on my X5000 for 6 months without any major issues. One thing to note, if the ethernet controller is just failing, the device tree may need updated. The device tree included with Linux is incomplete/incorrect, as the X5000 PHYs are attached via RGMII, not TBI. I have a device tree that works, at https://people.freebsd.org/~jhibbits/cy ... _amiga.dts , that you will need to compile with: dtc -I dts -O dtb -s 65536 -o cyrus_p5020_amiga.dtb cyrus_p5020_amiga.dts . The "-s 65536" is important, so that there's enough room for uboot fixups.
If you have a good device tree, or your kernel just isn't booting at all (gets stuck before even printing the Copyright message) you may need to recompile your dtb file to grow it, as mentioned above.
Here you are:
Download: cyrus_p5020_x5000.dtb
Compiled with the command:
dtc -I dts -O dtb -S 65536 -o cyrus_p5020_x5000.dtb cyrus_p5020_amiga.dts
Download: cyrus_p5020_x5000-2.dtb
dtc -I dts -O dtb -S 131072 -o cyrus_p5020_x5000-2.dtb cyrus_p5020_amiga.dts
Download: cyrus_p5020_x5000-3.dtb
make CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc cyrus_p5020.dtb
cp arch/powerpc/boot/cyrus_p5020.dtb ../cyrus_p5020_x5000-3.dtb
Please test them.
@Xeno74
Just replacing the new Blob for the one i am using now does not solve the DPAA network issues.
I have tried all three but not luck yet.
I will spend some more time on this later.
Skateman wrote:@Xeno74
Thank you for testing. Were you able to boot the X5000 with all three blobs?
Yeah the X5000 booted without problems with all blobs
daz
Post by daz »
I've had a look at this (yuk, it'd be a lot easier to read if you used symbols for phandles) and the changes seem to be the same as the ones we tried last year/earlier this year.
We've had the ethernet running with kernels derived from NXP's SDK, but not from main line. Where have you got your driver from? Can you try one of our hacked dtb files and see if it boots OK on FreeBSD? If it does we know we need to hassle the NXP guys to get it fixed. They think it could be an iommu config error in our firmware, which I assume would also break your driver.
Can you try the one here, seems to be the best option.
http://forum.hyperion-entertainment.biz ... =58&t=3945
Darren
chmeee
Post by chmeee »
daz wrote: I've had a look at this (yuk, it'd be a lot easier to read if you used symbols for phandles) and the changes seem to be the same as the ones we tried last year/earlier this year.
Darren
Sorry for the 4 month delay, been busy with a Talos and Tabor.
I'll try your config soon, but wanted to respond to your 'yuk' comment: The dts was generated as a dump from my X5000's uboot (fdt print /, or similar), post-'fdt boardsetup', so all the phandles have been mangled, then fixed up by me. It was most certainly not a manual creation.
- Justin
Hi Justin,
Thanks for your reply! :-) I compiled your dts file 4 months ago. Unfortunately the problem still exists with the DPAA network. Do you have another hint for us? Maybe you could compile your dts file for us again. We would be happy to test it.
chmeee
Post by chmeee »
xeno74 wrote:Hi Justin,
Hi Christian,
I just booted with your dtb. There was one change I needed to make with it: Yours is missing a /chosen node. FreeBSD needs a /chosen node with stdin and stdout properties. I also needed to make a change to FreeBSD, which I'll commit tonight.
My /chosen node looks like:
chosen {
    stdin = "serial0";
    stdout = "serial0";
- Justin
