Device Tree Blobs (dtb) for the X5000
I compiled the eth dtb file with poweroff support today.
Many thanks to Sinan for the hint.
Download: cyrus_p5020_eth_poweroff.dtb
Re: Device Tree Blobs (dtb) for the X5000
Source:
cyrus-pre.dtsi:
 * P5020/P5010 Silicon/SoC Device Tree Source (pre include)
 * Copyright 2011 - 2015 Freescale Semiconductor Inc.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 *     * Redistributions of source code must retain the above copyright
 *       notice, this list of conditions and the following disclaimer.
 *     * Redistributions in binary form must reproduce the above copyright
 *       notice, this list of conditions and the following disclaimer in the
 *       documentation and/or other materials provided with the distribution.
 *     * Neither the name of Freescale Semiconductor nor the
 *       names of its contributors may be used to endorse or promote products
 *       derived from this software without specific prior written permission.
 * ALTERNATIVELY, this software may be distributed under the terms of the
 * GNU General Public License ("GPL") as published by the Free Software
 * Foundation, either version 2 of that License or (at your option) any
 * later version.
 * THIS SOFTWARE IS PROVIDED BY Freescale Semiconductor ``AS IS'' AND ANY
 * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL Freescale Semiconductor BE LIABLE FOR ANY
 * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/dts-v1/;
/include/ "e5500_power_isa.dtsi"
	compatible = "fsl,P5020";
	#address-cells = <2>;
	#size-cells = <2>;
	interrupt-parent = <&mpic>;
	aliases {
		ccsr = &soc;
		dcsr = &dcsr;
		serial0 = &serial0;
		serial1 = &serial1;
		serial2 = &serial2;
		serial3 = &serial3;
		pci0 = &pci0;
		pci1 = &pci1;
		pci2 = &pci2;
		pci3 = &pci3;
		usb0 = &usb0;
		usb1 = &usb1;
		dma0 = &dma0;
		dma1 = &dma1;
		sdhc = &sdhc;
		msi0 = &msi0;
		msi1 = &msi1;
		msi2 = &msi2;
		crypto = &crypto;
		sec_jr0 = &sec_jr0;
		sec_jr1 = &sec_jr1;
		sec_jr2 = &sec_jr2;
		sec_jr3 = &sec_jr3;
		rtic_a = &rtic_a;
		rtic_b = &rtic_b;
		rtic_c = &rtic_c;
		rtic_d = &rtic_d;
		sec_mon = &sec_mon;
		raideng = &raideng;
		raideng_jr0 = &raideng_jr0;
		raideng_jr1 = &raideng_jr1;
		raideng_jr2 = &raideng_jr2;
		raideng_jr3 = &raideng_jr3;
		fman0 = &fman0;
		ethernet0 = &enet3;
		ethernet1 = &enet4;
	cpus {
		#address-cells = <1>;
		#size-cells = <0>;
		cpu0: PowerPC,e5500@0 {
			device_type = "cpu";
			reg = <0>;
			clocks = <&mux0>;
			next-level-cache = <&L2_0>;
			fsl,portid-mapping = <0x80000000>;
			L2_0: l2-cache {
				next-level-cache = <&cpc>;
		cpu1: PowerPC,e5500@1 {
			reg = <1>;
			clocks = <&mux1>;
			next-level-cache = <&L2_1>;
			fsl,portid-mapping = <0x40000000>;
			L2_1: l2-cache {
cyrus_p5020.dts:
 * Cyrus 5020 Device Tree Source, based on p5020ds.dts
 * Copyright 2015 Andy Fleming
 * p5020ds.dts copyright:
 * Copyright 2010 - 2014 Freescale Semiconductor Inc.
 * This program is free software; you can redistribute  it and/or modify it
 * under  the terms of  the GNU General  Public License as published by the
 * Free Software Foundation;  either version 2 of the  License, or (at your
 * option) any later version.
/include/ "cyrus-pre.dtsi"
	model = "varisys,CYRUS";
	compatible = "varisys,CYRUS";
	#size-cells = <2>;
	aliases {
		phy_rgmii_3 = &phy_rgmii_3;
		phy_rgmii_7 = &phy_rgmii_7;
	memory {
		device_type = "memory";
	reserved-memory {
		#size-cells = <2>;
		ranges;
		bman_fbpr: bman-fbpr {
			size = <0 0x1000000>;
			alignment = <0 0x1000000>;
		qman_fqd: qman-fqd {
			size = <0 0x400000>;
			alignment = <0 0x400000>;
		qman_pfdr: qman-pfdr {
			size = <0 0x2000000>;
			alignment = <0 0x2000000>;
	dcsr: dcsr@f00000000 {
		ranges = <0x00000000 0xf 0x00000000 0x01008000>;
	bportals: bman-portals@ff4000000 {
		ranges = <0x0 0xf 0xf4000000 0x200000>;
	qportals: qman-portals@ff4200000 {
		ranges = <0x0 0xf 0xf4200000 0x200000>;
	soc: soc@ffe000000 {
		ranges = <0x00000000 0xf 0xfe000000 0x1000000>;
		reg = <0xf 0xfe000000 0 0x00001000>;
		spi@110000 {
		i2c@118100 {
		i2c@119100 {
			rtc@6f {
				compatible = "microchip,mcp7941x";
				reg = <0x6f>;
		fman@400000 {
			mdio@e1120 {
				phy_rgmii_3: ethernet-phy@3 {
					reg = <0x3>;
				phy_rgmii_7: ethernet-phy@7 {
					reg = <0x7>;
			ethernet@e6000 {
				phy-handle = <&phy_rgmii_3>;
				phy-connection-type = "rgmii";
			ethernet@e8000 {
				phy-handle = <&phy_rgmii_7>;
	rio: rapidio@ffe0c0000 {
		reg = <0xf 0xfe0c0000 0 0x11000>;
		port1 {
			ranges = <0 0 0xc 0x20000000 0 0x10000000>;
		port2 {
			ranges = <0 0 0xc 0x30000000 0 0x10000000>;
	lbc: localbus@ffe124000 {
		reg = <0xf 0xfe124000 0 0x1000>;
		ranges = <0 0 0xf 0xe8000000 0x08000000
			  2 0 0xf 0xffa00000 0x00040000
			  3 0 0xf 0xffdf0000 0x00008000>;
	pci0: pcie@ffe200000 {
		reg = <0xf 0xfe200000 0 0x1000>;
		ranges = <0x02000000 0 0xe0000000 0xc 0x00000000 0x0 0x20000000
			  0x01000000 0 0x00000000 0xf 0xf8000000 0x0 0x00010000>;
		pcie@0 {
				  0 0x20000000
				  0 0x00010000>;
	pci1: pcie@ffe201000 {
		reg = <0xf 0xfe201000 0 0x1000>;
		ranges = <0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x20000000
			  0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000>;
		pcie@0 {
				  0 0x20000000
				  0 0x00010000>;
	pci2: pcie@ffe202000 {
		reg = <0xf 0xfe202000 0 0x1000>;
		ranges = <0x02000000 0 0xe0000000 0xc 0x40000000 0 0x20000000
			  0x01000000 0 0x00000000 0xf 0xf8020000 0 0x00010000>;
		pcie@0 {
				  0 0x20000000
				  0 0x00010000>;
	pci3: pcie@ffe203000 {
		reg = <0xf 0xfe203000 0 0x1000>;
		ranges = <0x02000000 0 0xe0000000 0xc 0x60000000 0 0x20000000
			  0x01000000 0 0x00000000 0xf 0xf8030000 0 0x00010000>;
		pcie@0 {
				  0 0x20000000
				  0 0x00010000>;
	gpio-poweroff {
		compatible = "gpio-poweroff";
		gpios = <&gpio0 3 1>;
	gpio-restart {
		compatible = "gpio-restart";
		gpios = <&gpio0 2 1>;
	leds {
		compatible = "gpio-leds";
		hdd {
			label = "Disk activity";
			gpios = <&gpio0 5 0>;
			linux,default-trigger = "disk-activity";
/include/ "p5020si-post.dtsi"
Command for building the dtb file:
make ARCH=powerpc cyrus_p5020.dtb
The DTB works great!!
The X5000 powers down like it should!
Thanks again!
I compiled a new dtb file with poweroff support for the AmigaOne X5000/40 today.
Download: Device_Tree_Blob_X5000_40_with_poweroff_support.tar.gz
xeno74 wrote:Hi All,
Tested this on my X5000 /20 just because i could :-) Machine did boot, DPAA Nic not probed... as expected
Darren has released new device tree blobs (dtbs) for the X5000/20 and X5000/40.
You can find them in the latest kernel package.
Download: linux-image-5.7-rc4-X1000_X5000.tar.gz
He sent some patches to the Linux-ppc mailing today.
Link to the thread: powerpc/mpc85xx: Define ethernet port aliases in board dts file
Many thanks to Darren!
