Skip UBoot animation?
Re: Skip UBoot animation?
Works for me.
U-Boot 2014.04 (Oct 17 2016 - 08:22:22)
JohnFante
Post by JohnFante »
tommysammy wrote: Where can we get it?
I second that! :D
If anybody could upload the latest Uboot, that would be great. I am running the older "Costel-version" and I would very much like to get my boot time dowm.
Thank you in advance!
X5000 :-)
JohnFante
Post by JohnFante »
Bumping this to see if I am so lucky that someone has the latest official Uboot for X5000 from October last year .... :-)
X5000 :-)
U-Boot is not a Hyperion product, so I suggest you contact AmigaKit/A-Eon for the latest copy. They can also give you the little utility that will update it for you under OS4, without using U-Boot itself (requires a running OS4 system, of course).
daveyw
Post by daveyw »
Where can I check the uBoot version?
JohnFante
Post by JohnFante »
tonyw wrote:U-Boot is not a Hyperion product, so I suggest you contact AmigaKit/A-Eon for the latest copy. They can also give you the little utility that will update it for you under OS4, without using U-Boot itself (requires a running OS4 system, of course).
I know :-)
Have been in contact with Trevor but since he has been on the road for a while I thought that I would check here.
X5000 :-)
Amigo1
Post by Amigo1 »
I know :-)
Would be nice if you could post the version number of the latest U-Boot for us unknowing people to know. when you yourself are in the knowing of course. :)
It's not a version per se, but an embedded date.
My current U-Boot (which is the latest AFAIK) has a (n embedded) date of 17.10.2016. I don't have the original downloaded binary any more so I can't tell you anything about that.
The previous version (again, AFAIK) was 10.09.2016.
daveyw
Post by daveyw »
They should make it more widely available, but I guess they're worried someone will brick their machines (or maybe just the SD card??)
I finally fouind mine, it is "2014.04 (Oct". Isn't this the version Spectre660 had ???
This is the version that my motherboard came with .
daveyw wrote:They should make it more widely available, but I guess they're worried someone will brick their machines (or maybe just the SD card??)
