openSUSE Tumbleweed
Re: openSUSE Tumbleweed
Roland,
I think I have found the issue. Many apps aren't compatible with the P5020 CPU. For example LightDM and libLLVM.so.7.
Please boot to the runlevel 3 with the boot argument "3":
For example:
setenv bootargs root=/dev/sdb 3
Login as "root" (password: amigaone) and rename the libLLVM.so.7 to libLLVM.so.7.bak with the following command:
mv /usr/lib64/libLLVM.so.7 /usr/lib64/libLLVM.so.7.bak
After that you can start Xorg with "startx".
I was able to start iceWM (command: icewm) and FVWM2 (command fvwm). MATE and XFCE don't work.
Sorry,
xeno74 wrote: Please boot to the runlevel 3 with the boot argument "3
What does this runlevel argument actually do...? What values are possible, and what is the default if you do not define it?
"icewm" did nothing but the other option worked for me - THANKS !-) In fact, I have not used FVWM2 before, quite funny and original...
Roland wrote: What does this runlevel argument actually do...?
Runlevel -- Wikipedia
