Hi Roland,Roland wrote: MANY THANKS Christian - that did the trick!!!
Fantastic news!
Thanks in advance,
Tested... It works with both kernels if the 'MEM=3500M' variable is set.
I found for Debian a package called "scsitools", which includes a "scsi-spin" command. With options -u and -d a any drive can be spinned up or down. It seems to work...Roland wrote:Speaking of SCSI disks, is there for Linux a similar program/command like "scsiswitch" for AmigaOS? With it you can e.g. spin up and down a scsi disk. That is handy for disks which you use only occasionally, e.g. for backups or confidental data.
