Spectre660's Linux downloads for the X5000
Re: Spectre660's Linux downloads for the X5000
@ monkey01
Interesting it works ok for me . re Installed over my lunch hour today. Daz also experienced a problem though.
(Just got my X5000 about 2 weeks ago but tested ok first on my Sam460ex).
Are you using one of my kernels or not ? .
Can you list all the components of your machine.
I dont have a DVD drive connected .
only one Hard drive and only use the on board SATA . no other SATA controllers .
My USB thumb drive with kernel and ramdisk is on a hub and is the only device connected to the hub.
Any extra USB devices or Hubs in the keyboard on your machine ?
monkey01 wrote:
Spectre660 wrote:Ubuntu 16.04 ramdisk installer
https://drive.google.com/open?id=0BxoZd ... 3RvbWpfeWc
Copy the ramdisk to a Fat32 formatted thumb drive with your kernel of choice and cyrus_520.dtb
boot the installer with the U-boot options below to install Ubuntu-Mate 16.04 .
usb reset
setenv bootargs root=/dev/ramdisk mem=3500M radeon.pcie_gen2=1
fatload usb 0:1 1000000 uImage-cyrus
fatload usb 0:1 1c00000 cyrus_5020.dtb
fatload usb 0:1 2000000 uRamdisk_Ubuntu-Mate_16.04_net
bootm 1000000 2000000 1c00000
On my X5000 the installer hangs at the point where he scans the disks.
The debian installer wents fine. any advices?
monkey01
Post by monkey01 »
So i will get here the summary.
Amiga SSD is in SATA 0
Linux HDD is in SATA 1
On the Motherboard USB ist al Multi Card Reader with USB-Port.
The Linux HDD ist parted msdos with 3 Partitions
1. Fat32 900 MB for the kernels
2. EXT4 with Debian 8
3. SWAP
The DVD Rom is at the moment not connect.
In one PCI port is a 2 way SATA Controller with nothing connect
So i wrote that your Debian 8 installer with mate Desktop boot like a charm and i was able to install the Software completely.
by the way i tested also booting the kernel and ramdisk from the usb stick but the ubuntu mate ramdisk hangs at partet.
My Graphicscard is •RadeonHD R7 250 mit 1 GB DDR5
i boot with the kernel 4.11
@ monkey01
Need to try to eliminate the problem one step at a time.
First can you use this kernel (and use it for each test)
https://drive.google.com/open?id=0BxoZd ... 3MtWTU1UWc
monkey01
Post by monkey01 »
Spectre660 wrote:@ monkey01
i tested i have another problem
i did anything wrong no my X5000 boots automatically linux debian
and not Amiga OS 4.1 :) :o
How can i fix it ?
edit: fixed :)
monkey01
Post by monkey01 »
Booting Kernel 4.9.33 Error boot here Screenshot ..
@ monkey01
What model sound card do you have ?
Does it have a gameport ?
monkey01
Post by monkey01 »
@ spectre660
Creative Labs Soundblaster Live.
Cause under OS 4.1 i had issues with the first cmi soundcard.
@ monkey01
Can you try to boot with the kernel linked below please .
is a 4.12-rc7 kernel and I have removed the gameport support .
It could be some trial and error to eliminate the problems .
We need to have you booting with one of my kernels to eliminate any difference in kernel configuration as a problem.
Or we could go the lazy way and use the Ubuntu-Mate .img that we first used for the installation.
Would have to upload it again and it would take some time unless dropbox has it in deleted files.
Also what model PCI SATA card do you have ?
https://drive.google.com/open?id=0BxoZd ... GkyOGZ0XzQ
monkey01
Post by monkey01 »
@:spectre660
InLine® PCI SCHNITTSTELLENKARTE SATA (S-ATA)CONTROLLER KARTE(SILICON IMAGE 3512)
I test your kernel tomorrow. :)
monkey01
Post by monkey01 »
So one good message and one bad....
First good message Kernel boots till installer...
But partman hangs by scanning harddisks:
At a console F4 here the error codes :
