Spectre660's Linux downloads for the X5000
Re: Spectre660's Linux downloads for the X5000
Spectre660 wrote:X5000 4.14.1 Kernel .
http://dl.dropboxusercontent.com/s/1b05 ... ar.gz?dl=0
Thank you :-)
Ribdevil
Post by Ribdevil »
Hi, to all.
I'm new in Linux.
Install Lubuntu 16.04 LTS3 with your last kernel 4.9.61.
Works, a bit slow, but works, make the system updates and try TuxKarts.
I only get a blank window with the name, so I think that I make something wrong.
What ?
Install other simple game ( power manga )and it works fine.
Virginio
Ribdevil wrote:Hi, to all.
I'm new in Linux.
What ?
Virginio
Hi Virginio,
Could you please post the output of glxinfo | grep -i opengl ?
Ribdevil
Post by Ribdevil »
I'm new in Linux.
What ?
Virginio
Hi Virginio,
Hi, Spectre.
I get this :
vir@X5000L:~/Escritorio$ glxinfo |grep -i opengl
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 4.0, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 17.0.7
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 17.0.7
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 17.0.7
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
One more thing, my graphics board is : RAdeon R9 270, may be this is the problem.
Virginio
Ribdevil wrote: I get this :
OpenGL extensions:
Virginio
Hi Virginio,
Linux PowerPC doesn't offer hardware 3D acceleration for your graphics card. The behaviour of SuperTuxKart is normal. It needs hardware 3D acceleration.
Ribdevil
Post by Ribdevil »
I imagined it, thanks for the confirmation.
Greetings.
Virginio
P.D. I have a 9250 pci, can I put both?
So would I have 3D by the 9250?
How to do it ?
Thank you very much and apologize for any inconvenience.
Ribdevil wrote: P.D. I have a 9250 pci, can I put both?
How to do it ?
Here you are: forum.hyperion-entertainment.biz
With the Radeon 9250 PCI heavy 3D stuff like games are causing screen corruption then crash.
Blender gui is working . Neverball works.
I am trying to get my hands on a PCI Radeon HD to test but I not sure if it will work well.
The PCI Radeon HD's have PEX 8112 bridge chip.
Using a PCI to PCIE adpater with the PEX 8112 bridge chip and a PCIE Radeon HD worked under Linux but was slow and caused AmigaOS 4.1 to freeze just as Workbench was being displayed during boot.
So apparently a problem with AmigaOS 4.1 ?
How to do it ?
