Spectre660's Linux downloads for the X5000
Re: Spectre660's Linux downloads for the X5000
@ Caseycullen
Install a full Debian 8 Mate with my installer ramdisk below.
https://drive.google.com/open?id=0BxoZd ... Fo4clZzUmc
Copy the ramdisk to a Fat32 formatted thumb drive with your kernel of choice and cyrus_520.dtb
boot the installer with the uboot options below and install Debian 8 .
usb reset
setenv bootargs root=/dev/ramdisk mem=3500M radeon.pcie_gen2=1
fatload usb 0:1 1000000 uImage-cyrus
fatload usb 0:1 1c00000 cyrus_5020.dtb
fatload usb 0:1 2000000 uRamdisk_Debian_8-net
bootm 1000000 2000000 1c00000
After the installation clone the partition from Ubuntu Mate using gparted . You could also use dd from the newly installed Debian 8 .
Boot from the newly installed or cloned Debian 8 partition then upgrade .
You can skip the cloning if you don't also want to keep a Debian 8 installation .
after cloning the partition and booting from it change the /etc/apt/sources.list to
deb http://ftp.us.debian.org/debian/ unstable main contrib non-free
deb-src http://ftp.us.debian.org/debian/ unstable main contrib non-free
upgrade to Debian 9/sid with:
apt-get update
apt-get -u dist-upgrade
PS: I have also done a Gentoo installer image that boots but I have not tried to do an installation yet.
if your are interested in trying it just ask.
caseycullen wrote:
Spectre660 wrote:Debian Sid on X5000
Hi Julian,
How did you install Debian Sid?
---Casey
X5000 4.9.34 Kernel.
Configured for gpio poweroff but can't get it to work so compiled without the poweroff patch .
Also archive also includes a dtb file again made without the poweroff patch.
This dtb file used the default name which is cyrus_p5020.dtb the older ones don't have the "p" in the name (cyrus_5020.dtb)
https://drive.google.com/open?id=0BxoZd ... G9CeW44Q3M
Hi Guys ,
You might be interested in trying this X5000 Gentoo Minimal Install USB image that I did .
http://dl.dropboxusercontent.com/s/2d49 ... 1.img?dl=0
image is of a 512mb SD card so not too big.
Have only only checked that it boots ok but have not tried an actual installation.
Have never used Gentoo myself but the install instructions can be found here :
https://wiki.gentoo.org/wiki/Handbook:PPC
Bootloader section would not apply as is for Uboot machines .
dd the image to a USB thumb drive .
Kernel,dtb and ramdisk all on the single usb partition along with the squashfs etc.
Uboot stuff something like this:
usb reset
setenv bootargs root/dev/ram0 init=/linuxrc looptype=squashfs loop=/image.squashfs cdroot rootdelay=10 mem=3500M
Spectre660 wrote:X5000 4.9.34 Kernel.
It works. :-) Many thanks!
@xeno74
Thank you Christian .
Debian 8 (Jessie) ramdisk installer
https://drive.google.com/open?id=0BxoZd ... zRaQ3VrM0E
boot the installer with the U-boot options below to install Debian 8 .
usb reset
Ubuntu 16.04 ramdisk installer
https://drive.google.com/open?id=0BxoZd ... GI4S2NXd3M
boot the installer with the U-boot options below to install Ubuntu-Mate 16.04 .
usb reset
fatload usb 0:1 2000000 uRamdisk_Ubuntu-Mate_16.04_net
caseycullen
Post by caseycullen »
Great; will try this out sometime this week, thanks!
---Casey
Spectre660 wrote:@ Caseycullen
usb reset
apt-get update
@ All
Note that the installers partitioner treats NGFS partitions as empty space so be careful .
monkey01
Post by monkey01 »
Spectre660 wrote:Ubuntu 16.04 ramdisk installer
https://drive.google.com/open?id=0BxoZd ... 3RvbWpfeWc
usb reset
On my X5000 the installer hangs at the point where he scans the disks.
The debian installer wents fine. any advices?
