Gorky 17 - saves don't ..save
mjnurney
Post by mjnurney »
hello
Ive tried posting this in the game section but there is no Newtopic or reply button option so ...
Anyway I've just bought Gorky17 and i love it , it plays great but...
The save feature doesn't work ...it allows naming a save point and bleeps on the save screen but when you try loading...its gone
any idea why ? it kind of make progression a bit slow when i can't save my progress...
cheers,
mike.
mjnurney
Re: Gorky 17 - saves don't ..save
Post by mjnurney »
I'm stumped ...it allows my to enter a name for the save but it then bleeps but on the load screen there is nothing ?
heres a vid of the offending game.
mike.
https://youtu.be/3O9xB64xzhI
Cyborg
Post by Cyborg »
Looking at your video, it looks like the SAVEGAME drawer is missing. Please create a drawer called SAVEGAME inside the game drawer and try again.
Please contact support@hyperion-entertainment.com rather than trying to send PMs to me. Thanks! :)
mjnurney
Post by mjnurney »
Yes that sorted it , it now saves.
I had deleted the game and copied it over again (Digital Dowloand but it doesn't make a savegame folder)
all good now.
and i can reply here now too...
Cyborg
Post by Cyborg »
Good to hear your issues are solved! :)
Indeed the SAVEGAME drawer was missing from the distribution archive. This is also fixed now on our servers, so this shouldn't happen anymore in future. My apologies for any inconvenience!
mjnurney
Post by mjnurney »
Not a problem, just nice to see it working properly.
Its the first Amiga game I've bought in 20 years...
Discovery69
Post by Discovery69 »
Good morning
I'm having problems saving Gorky 17 with OS4.1fe Update 2. The game crashes.
Are you aware of the problem?
I double-tested by putting the update1 Kickstart back on and it works.
(Amiga NG Sam440/460)
Louis.
