EHCI task crashes while copying from a µSD card.
Deniil
Post by Deniil »
Well, other more random/difficult to track down USB issues aside, I have one issue that keeps occuring occasionally (like once or twice per GB of reading).
I get this: Task "EHCI Controller Task Unit 0" crashed. It is a DSI and it *always* occurs at address 0xA002000C. It is ignorable and the transfer then continues as if nothing had happened. I ran md2sum on the (few 100MB large) file I copied and it copied correctly even though this DSI happened and was ignored.
Something else that happens even more often is that DOS freezes for about 10 seconds during a transfer (file copy). Everything that accesses DOS, like playing music (after IO buffer runs out) and the USB transfer itself then halts, and then continues normally after 10 or so seconds. I find this behaviour very wierd. Input and intuition does not hang during this period.
I have a NEC USB U-143 card in the 3rd and lowermost 33MHz slot. All information you need should be in the crashlog I will attach.
EDIT: The silly forum doesn't allow neither .txt nor .lha files as attachments :evil:
Posting the log here instead then....:
Hidden Text - Click to Show :
Crash log for task "EHCI Controller Task Unit 0"
Generated by GrimReaper 53.2
Crash occured in module ehci.usbhcd at address 0x018B1870
Register dump:
0: 00000020 6FDEDEB0 A21222A2 00000000 01C5143C 00000000 01DA3650 01DA3674
8: 00000001 A002000C 00000001 00000020 6FF028A0 AA9A28A8 AA128622 6FFFEB80
16: 6FFFEB90 6FE2CA60 BE009000 06008000 63230568 0000001F 018B8A28 6FE2C958
24: 0000001F 6FE2C534 04000000 00000000 6FFFEA80 00000000 02000000 6FE2C000
0: nan 6.55706e+281 1.78461e+141 -3.23218e+251
4: -6.79544e+200 5.12313e+271 -2.19668e+199 7.43098e-06
8: 1.30283e-191 -3.93015e-195 -2.00994e-69 -2.69617e+12
12: -6.75776e-35 4.92147e-96 0 0
16: 0 0 0 0
20: 0 0 0 0
24: 0 0 0 0
28: 0 0 0 0
FPSCR (Floating Point Status and Control Register): 0x82008000
Machine State (msr) : 0x0000F030
Condition (cr) : 0x53051999
Instruction Pointer (ip) : 0x018B1870
Xtended Exception (xer) : 0x8000A829
Count (ctr) : 0x01412C98
Link (lr) : 0x018B17FC
DSI Status (dsisr) : 0x40000000
Data Address (dar) : 0xA002000C
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x018B1870 belongs to module "ehci.usbhcd" (HUNK/Kickstart)
Stack trace:
native kernel module ehci.usbhcd+0x000003f0
native kernel module ehci.usbhcd+0x00002540
native kernel module ehci.usbhcd+0x000060c4
native kernel module kernel+0x0001d668
PPC disassembly:
018b1868: 90010010 stw r0,16(r1)
018b186c: 6129000c ori r9,r9,12
*018b1870: 80090000 lwz r0,0(r9)
018b1874: 3d2001e7 lis r9,487
018b1878: 8069f348 lwz r3,-3256(r9)
System information:
CPU
Model: Motorola MPC 7445/7455 Apollo V2.1
CPU speed: 933 MHz
FSB speed: 133 MHz
Extensions: performancemonitor altivec
Machine
Machine name: AmigaOne
Memory: 524288 KB
Extensions: bus.pci bus.agp
Expansion buses
PCI/AGP
00:00.0 Vendor 0x10CC Device 0x0660
Range 0: 00000000 - 00400000 (PREF.MEM)
00:01.0 Vendor 0x10CC Device 0x0661
00:06.0 Vendor 0x10B7 Device 0x9200
Range 0: 00802000 - 00802080 (IO)
Range 1: 98100000 - 98100080 (MEM)
00:07.0 Vendor 0x1106 Device 0x0686
00:07.1 Vendor 0x1106 Device 0x0571
Range 4: 0000CC00 - 0000CC10 (IO)
00:07.2 Vendor 0x1106 Device 0x3038
Range 4: 00802080 - 008020A0 (IO)
00:07.3 Vendor 0x1106 Device 0x3038
Range 4: 008020A0 - 008020C0 (IO)
00:07.4 Vendor 0x1106 Device 0x3057
00:07.5 Vendor 0x1106 Device 0x3058
Range 0: 0000DC00 - 0000DD00 (IO)
Range 1: 0000E000 - 0000E008 (IO)
Range 2: 0000E400 - 0000E408 (IO)
00:07.6 Vendor 0x1106 Device 0x3068
Range 0: 00802300 - 00802400 (IO)
00:08.0 Vendor 0x1095 Device 0x0680
Range 0: 00802400 - 00802408 (IO)
Range 1: 00802408 - 00802410 (IO)
Range 2: 00802410 - 00802418 (IO)
Range 3: 00802418 - 00802420 (IO)
Range 4: 00802420 - 00802430 (IO)
00:09.0 Vendor 0x13F6 Device 0x0111
Range 0: 0000FF00 - 00000000 (IO)
00:0A.0 Vendor 0x1033 Device 0x0035
Range 0: 98101000 - 98102000 (MEM)
00:0A.1 Vendor 0x1033 Device 0x0035
Range 0: 98102000 - 98103000 (MEM)
00:0A.2 Vendor 0x1033 Device 0x00E0
Range 0: 98103000 - 98103100 (MEM)
01:00.0 Vendor 0x1002 Device 0x5960
Range 0: 80000000 - 88000000 (PREF.MEM)
Range 1: 00002000 - 00002100 (IO)
Range 2: 88000000 - 88010000 (MEM)
01:00.1 Vendor 0x1002 Device 0x5940
Range 0: 90000000 - 98000000 (PREF.MEM)
Range 1: 98000000 - 98010000 (MEM)
Libraries
0x69c5c7f4: vapor_toolkit.library V15.13 (Legacy)
0x6c137398: ISO-8859-15.charset V52.1
0x6c137318: english_ISO-8859-15.language V52.1
0x01db6866: exec.library V53.22
0x6ff2f174: vilintuisup.library V0.9
0x6ff2f048: cgxvideo.library V42.1
0x6ff660e0: cybergraphics.library V43.0
0x5b8091f0: mathieeesingbas.library V52.1
0x5b8090fc: virtual.gadget V53.6
0x5ba9e840: NBitmap.mcc V15.14
0x5b1dc06e: Busy.mcc V17.37 (Legacy)
0x5ba9e340: aiff.datatype V53.1
0x5ba9e0c0: 8svx.datatype V53.1
0x5ba9e200: sound.datatype V53.6
0x5c2a0e10: Levelmeter.mui V20.303
0x5c30bb1a: CManager.library V10.5 (Legacy)
0x693bff2e: Textinput.mcc V29.2001 (Legacy)
0x5c2a0b90: Popmenu.mui V20.77
0x5c2a0af0: bmp.datatype V53.2
0x6379cf40: Imagedisplay.mui V20.200
0x6379cd60: Pendisplay.mui V20.191
0x6379c4a0: ilbm.datatype V53.1
0x67dd392c: xpkSQSH.library V1.10 (Legacy)
0x69d7320c: xpkSMPL.library V1.0 (Legacy)
0x66752c6c: xpkSHRI.library V2.2 (Legacy)
0x6379d0fc: xpkRLEN.library V1.3 (Legacy)
0x69d73a8c: xpkRAKE.library V1.7 (Legacy)
0x6ff06e2c: xpkNUKE.library V1.7 (Legacy)
0x69d73b8c: xpkNONE.library V1.4 (Legacy)
0x6379c19c: xpkMASH.library V1.98 (Legacy)
0x69d73be8: xpkLZMA.library V52.2
0x6379c092: xpkIMPL.library V1.0 (Legacy)
0x66751d6c: xpkIDEA.library V1.3 (Legacy)
0x66751c4c: xpkHUFF.library V0.64 (Legacy)
0x69d73d0c: xpkHFMN.library V1.36 (Legacy)
0x69d73d8c: xpkFRLE.library V1.0 (Legacy)
0x667519ac: xpkFEAL.library V1.5 (Legacy)
0x667518ec: xpkFAST.library V1.10 (Legacy)
0x667516ac: xpkENCO.library V1.3 (Legacy)
0x667517cc: xpkDUKE.library V1.6 (Legacy)
0x688bd86c: xpkDLTA.library V0.1 (Legacy)
0x67dd383c: xpkCBR0.library V1.0 (Legacy)
0x69b89c3c: xpkBZP2.library V1.7
0x69b89bb4: xpkmaster.library V5.2
0x67dd2b70: TextEditor.mcc V15.36
0x67dd2ad0: NBalance.mcc V15.10
0x67dd2a30: NListtree.mcc V18.36
0x67dd2990: NFloattext.mcc V19.65
0x67dd2850: TheButton.mcc V26.7
0x67dd27b0: TheBarVirt.mcc V26.7
0x67dd2710: TheBar.mcc V26.7
0x6985ab48: amissl_v097g.library V3.7
0x67dd24a8: amisslmaster.library V3.7
0x68848cf0: expat.library V53.3
0x69e702b8: bz2.library V53.2
0x67dd2350: Pixmap.mui V20.2
0x67b593fc: xadmaster.library V13.1
0x6c295834: amigaguide.datatype V53.2
0x67dd10d4: amigaguide.library V53.2
0x692563d8: dopus.library V22.40
0x67dd2030: fuelgauge.gadget V53.8
0x687a9e78: xenbar.image V20.189
0x687a9d40: Dtpic.mui V20.190
0x687a9b60: Popasl.mui V20.199
0x687a9a20: BetterString.mcc V11.20
0x687a98e0: Listtree.mcc V20.41
0x69c208bc: codesets.library V6.12
0x69b7e0d8: pthreads.library V53.7
0x69d3bb5e: rexxsupport.library V34.9 (Legacy)
0x693c7cc0: Lamp.mcc V20.10
0x693c7b80: palette.gadget V53.6
0x69c200e0: texteditor.gadget V53.18
0x6fd407b8: radiobutton.gadget V53.9
0x693c7900: Gauge.mui V20.225
0x693c77c0: NListview.mcc V19.84
0x693c7720: NList.mcc V20.129
0x69d904c4: asyncio.library V50.3
0x693c758c: taglist.library V1.3 (Legacy)
0x6c11ad2c: muimaster.library V20.2311
0x69d7acb8: Lens.docky V52.1
0x69d64d38: SubDock.docky V53.1
0x69543a5e: reqtools.library V39.3 (Legacy)
0x693c70e0: slider.gadget V53.12
0x6996ccb0: getfont.gadget V53.8
0x6964b190: requester.class V53.18
0x6996cb70: getfile.gadget V53.10
0x6996cdf0: space.gadget V53.6
0x6996cd50: integer.gadget V53.10
0x69e71dc8: clicktab.gadget V53.38
0x6c2dae48: chooser.gadget V53.18
0x6996c7b0: penmap.image V53.5
0x699a8c58: screenblanker.library V53.3
0x6996c670: checkbox.gadget V53.9
0x69183f20: arexx.class V53.3
0x6c1162b0: bitmap.image V53.9
0x6b014c78: listbrowser.gadget V53.49
0x6b9c09e0: string.gadget V53.16
0x6c1160d0: scroller.gadget V53.11
0x6ba15e80: jpeg.datatype V53.5
0x6bb75728: emulation.library V41.446
0x6be0a558: cmi8738.audio V5.17
0x6bdbfcd4: device.audio V6.2
0x6c2dab84: filesave.audio V6.3
0x6be0a6d8: via-ac97.audio V5.9
0x6be0aa20: mathieeedoubbas.library V52.1
0x6bd91aec: textclip.library V52.2
0x6bc2a2d0: button.gadget V53.14
0x6bc2a410: glyph.image V53.3
0x6be080d0: window.class V53.42
0x6bdbf6f8: popupmenu.class V53.2
0x6c13c098: popupmenu.library V53.5
0x6bc2a190: label.image V53.12
0x6ff2fd68: layout.gadget V53.19
0x6bdbf600: bevel.image V53.6
0x6c1daea0: drawlist.image V53.3
0x6c1da9a0: png.datatype V53.6
0x6bd00464: picture.datatype V53.6
0x6be03554: asl.library V53.45
0x6c2b3c48: timezone.library V53.6
0x6be57038: application.library V53.12
0x6c2da84c: ft2.library V53.1
0x6c29c08c: workbench.library V53.37
0x6c1878b0: Picasso96API.library V2.356
0x6c1d72a0: gadtools.library V53.4
0x6c13b9bc: commodities.library V53.1
0x6c2ca140: datatypes.library V53.4
0x6c1885d4: usergroup.library V4.30
0x6c2ae8f0: bsdsocket.library V4.292
0x6c6688cc: icon.library V53.13
0x6fe09238: version.library V53.7
0x6c2952d0: iffparse.library V53.1
0x6ffb5ccc: locale.library V53.3
0x6ff6041c: diskfont.library V53.4
0x6ff94d98: petunia.library V53.3
0x6ff94c18: diskcache.library V3.30
0x6fd6e654: dos.library V53.76
0x6ff2f444: usbprivate.library V53.11
0x6ff8feac: massstorage.usbfd V53.13
0x6ff8fe18: bootkeyboard.usbfd V52.3
0x6ff8fd98: bootmouse.usbfd V53.1
0x6ff2f2fc: hub.usbfd V53.8
0x6ff2f24c: usbresource.library V53.11
0x6ff5f658: hunk.library V53.4
0x6ff94354: elf.library V53.14
0x6ff894d0: intuition.library V53.32
0x6ff43150: rtg.library V41.4355
0x6ff8f8a0: ATIRadeon.chip V53.23
0x6ff8f824: PCIGraphics.card V53.1
0x6ffaaa10: keymap.library V53.3
0x6ff85510: layers.library V53.6
0x6ffb4420: graphics.library V53.4
0x6ff5f0e4: nonvolatile.library V52.1
0x6ffab318: newlib.library V53.18
0x6ff951ac: utility.library V53.3
0x6ffaa0a8: expansion.library V53.1
0x6bef21fe: rexxsyslib.library V45.7 (Legacy)
Devices
0x5afe00b8: usbdisk.device V53.13
0x69e45164: clipboard.device V53.2
0x6bb9a164: ahi.device V6.6
0x6c200bc4: eth3com.device V53.2
0x6ff95b10: usbsys.device V53.11
0x6ff5f9b0: ehci.usbhcd V53.15
0x6ff5f910: ohci.usbhcd V53.18
0x6ff5f870: uhci.usbhcd V53.7
0x6ff5f7a4: sii0680ide.device V53.8
0x6ffa8628: console.device V53.1
0x6ff963f0: ramdrive.device V52.6
0x6ffaac5c: input.device V53.3
0x6ffa8314: keyboard.device V53.5
0x6ffaa774: gameport.device V52.1
0x6ff962d0: timer.device V53.1
Tasks
ahi.device Unit Process (Waiting)
Stack: 0x6b992004 - 0x6b9a1ffc, pointer @ 0x6b9a1f20 (Cookie OK)
Signals: SigRec 0xf000c000, SigWait 0x00000100
State: Process (Waiting)
Background CLI [A-Progg:bredbandsuger] (Waiting)
Stack: 0x691db004 - 0x691e2ffc, pointer @ 0x68802460 (Cookie OK)
AmigaAMP PlayTask (Waiting)
Stack: 0x5bf4b004 - 0x5bf6affc, pointer @ 0x5bf6aec0 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000000
input.device (Waiting)
Stack: 0x6ff4b000 - 0x6ff5b000, pointer @ 0x6ff5af00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x6fd28004 - 0x6fd29ffc, pointer @ 0x6fd29f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x6fec3000 - 0x6fec7000, pointer @ 0x6fec6f20 (Cookie OK)
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x6fe0a000 - 0x6fe12000, pointer @ 0x6fe11f20 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fe32000 - 0x6fe3a000, pointer @ 0x6fe39f20 (Cookie OK)
AllKeys (Waiting)
Stack: 0x6a6dd004 - 0x6a6e4ffc, pointer @ 0x6a6e4810 (Cookie OK)
Signals: SigRec 0xf0001000, SigWait 0x00000000
EHCI Controller Task Unit 0 (Crashed)
Stack: 0x6fde6000 - 0x6fdee000, pointer @ 0x6fdedeb0 (Cookie OK)
Signals: SigRec 0x82000000, SigWait 0x84000000
State: Task (Crashed)
sii0680ide.device - chip 0 port 1 (Waiting)
Stack: 0x6fe66000 - 0x6fe6e000, pointer @ 0x6fe6df20 (Cookie OK)
eth3com.device (Waiting)
Stack: 0x6be7d004 - 0x6be8cffc, pointer @ 0x6be8cef0 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x10000000
sii0680ide.device - chip 0 port 0 (Waiting)
Stack: 0x6fe96000 - 0x6fe9e000, pointer @ 0x6fe9df20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x6fe3e004 - 0x6fe45ffc, pointer @ 0x6fe45e70 (Cookie OK)
WB0 (Waiting)
Stack: 0x6c90d004 - 0x6c90effc, pointer @ 0x6c90eed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
STO (Waiting)
Stack: 0x6c925004 - 0x6c926ffc, pointer @ 0x6c926eb0 (Cookie OK)
DH0 (Waiting)
Stack: 0x6fd22004 - 0x6fd23ffc, pointer @ 0x6fd23eb0 (Cookie OK)
JXF:DH5 (Waiting)
Stack: 0x6fd34004 - 0x6fd35ffc, pointer @ 0x6fd35de0 (Cookie OK)
Signals: SigRec 0xc0000100, SigWait 0x20000000
MainUSB0 (Waiting)
Stack: 0x5bb67004 - 0x5bb6effc, pointer @ 0x5bb6ed30 (Cookie OK)
USB0 (Waiting)
Stack: 0x5bb73004 - 0x5bb7affc, pointer @ 0x5bb7aee0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
reaper.task (Waiting)
Stack: 0x6c3d5004 - 0x6c3dcffc, pointer @ 0x6c3dcea0 (Cookie OK)
RAM (Waiting)
Stack: 0x6c65d004 - 0x6c664ffc, pointer @ 0x6c664c90 (Cookie OK)
DH2 (Waiting)
Stack: 0x6c91f004 - 0x6c920ffc, pointer @ 0x6c920eb0 (Cookie OK)
DH1 (Waiting)
Stack: 0x6c919004 - 0x6c91affc, pointer @ 0x6c91aeb0 (Cookie OK)
DH3 (Waiting)
Stack: 0x6c913004 - 0x6c914ffc, pointer @ 0x6c914eb0 (Cookie OK)
DH4 (Waiting)
Stack: 0x6fd3a004 - 0x6fd3bffc, pointer @ 0x6fd3beb0 (Cookie OK)
CD0 (Waiting)
Stack: 0x6fd2e004 - 0x6fd2fffc, pointer @ 0x6fd2ff20 (Cookie OK)
Vapor Toolkit Lib Rexx Reply Handler (Waiting)
Stack: 0x5baf6004 - 0x5bafdffc, pointer @ 0x5bafdf40 (Cookie OK)
Signals: SigRec 0xf0009000, SigWait 0x00000000
dos_filedir_notify (Waiting)
Stack: 0x6fd56004 - 0x6fd59ffc, pointer @ 0x6fd59ae0 (Cookie OK)
Signals: SigRec 0x10000000, SigWait 0x20000000
pager (Waiting)
Stack: 0x6c3b1004 - 0x6c3d0ffc, pointer @ 0x6c3d0f00 (Cookie OK)
Mixer (Waiting)
Stack: 0x691c4004 - 0x691cbffc, pointer @ 0x691cbc70 (Cookie OK)
Signals: SigRec 0x78001000, SigWait 0x00000100
ENV (Ready)
Stack: 0x6c5ed004 - 0x6c5eeffc, pointer @ 0x6c5eeda0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
State: Process (Ready)
MassStorage Device Task (Waiting)
Stack: 0x5bb4b004 - 0x5bb52ffc, pointer @ 0x5bb52d40 (Cookie OK)
Signals: SigRec 0x04000000, SigWait 0x80000100
URL (Waiting)
Stack: 0x6badd004 - 0x6bb57ffc, pointer @ 0x6bb53a90 (Cookie OK)
RANDOM (Waiting)
Stack: 0x6bb7a004 - 0x6bb81ffc, pointer @ 0x6bb81ef0 (Cookie OK)
CON (Waiting)
Stack: 0x5954e004 - 0x59555ffc, pointer @ 0x59555de0 (Cookie OK)
CON (Waiting)
Stack: 0x5b754004 - 0x5b75bffc, pointer @ 0x5b75bde0 (Cookie OK)
CON (Waiting)
Stack: 0x6a6c9004 - 0x6a6d0ffc, pointer @ 0x6a6d0de0 (Cookie OK)
CON (Waiting)
Stack: 0x5b98c004 - 0x5b993ffc, pointer @ 0x5b993de0 (Cookie OK)
console.device (Waiting)
Stack: 0x6fe9e000 - 0x6fea6000, pointer @ 0x6fea5f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
CON (Waiting)
Stack: 0x692b6004 - 0x692bdffc, pointer @ 0x692bdde0 (Cookie OK)
CON (Waiting)
Stack: 0x62a70004 - 0x62a77ffc, pointer @ 0x62a77de0 (Cookie OK)
CON (Waiting)
Stack: 0x6563c004 - 0x65643ffc, pointer @ 0x65643de0 (Cookie OK)
CON (Waiting)
Stack: 0x684be004 - 0x684c5ffc, pointer @ 0x684c5de0 (Cookie OK)
CON (Waiting)
Stack: 0x6c2c1004 - 0x6c2c8ffc, pointer @ 0x6c2c8de0 (Cookie OK)
CON (Waiting)
Stack: 0x69a5b004 - 0x69a62ffc, pointer @ 0x69a62de0 (Cookie OK)
CON (Waiting)
Stack: 0x69caa004 - 0x69cb1ffc, pointer @ 0x69cb1de0 (Cookie OK)
PowerSnap 2.2a © Nico François [PowerSnap-handler] (Waiting)
Stack: 0x69d86004 - 0x69d8dffc, pointer @ 0x69d8df80 (Cookie OK)
Signals: SigRec 0x23d01000, SigWait 0x00200000
CON (Waiting)
Stack: 0x693ed004 - 0x693f4ffc, pointer @ 0x693f4de0 (Cookie OK)
CON (Waiting)
Stack: 0x6956a004 - 0x69571ffc, pointer @ 0x69571de0 (Cookie OK)
CON (Waiting)
Stack: 0x69664004 - 0x6966bffc, pointer @ 0x6966bde0 (Cookie OK)
CON (Waiting)
Stack: 0x696e5004 - 0x696ecffc, pointer @ 0x696ecde0 (Cookie OK)
CON (Waiting)
Stack: 0x6975b004 - 0x69762ffc, pointer @ 0x69762de0 (Cookie OK)
CON (Waiting)
Stack: 0x697d1004 - 0x697d8ffc, pointer @ 0x697d8de0 (Cookie OK)
CON (Waiting)
Stack: 0x691b0004 - 0x691b7ffc, pointer @ 0x691b7de0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x6bab3004 - 0x6babaffc, pointer @ 0x6babaec0 (Cookie OK)
CON (Waiting)
Stack: 0x6c611004 - 0x6c618ffc, pointer @ 0x6c618de0 (Cookie OK)
RAW (Waiting)
Stack: 0x6c671004 - 0x6c678ffc, pointer @ 0x6c678de0 (Cookie OK)
CON (Waiting)
Stack: 0x6c68d004 - 0x6c694ffc, pointer @ 0x6c694de0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x6ff1f004 - 0x6ff20ffc, pointer @ 0x6ff20f20 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x6ff19004 - 0x6ff1affc, pointer @ 0x6ff1af00 (Cookie OK)
RexxMaster [] (Waiting)
Stack: 0x6ba40004 - 0x6ba47ffc, pointer @ 0x6ba47f50 (Cookie OK)
AmigaAMP (Waiting)
Stack: 0x61eec004 - 0x61f0bffc, pointer @ 0x61f0b7d0 (Cookie OK)
Signals: SigRec 0xff001000, SigWait 0x00800000
ScreenBlankerEngine (Waiting)
Stack: 0x696f1004 - 0x696f8ffc, pointer @ 0x696f8be0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000100
TEXTCLIP (Waiting)
Stack: 0x6bac9004 - 0x6bad0ffc, pointer @ 0x6bad0eb0 (Cookie OK)
ToolsDaemon [ToolsDaemon] (Waiting)
Stack: 0x69958004 - 0x6995fffc, pointer @ 0x6995ff70 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
compose.task (Ready)
Stack: 0x62534000 - 0x6253c000, pointer @ 0x6253bf30 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000020
State: Task (Ready)
Stack: 0x6a711000 - 0x6a719000, pointer @ 0x6a718f30 (Cookie OK)
State: Task (Ready)
Stack: 0x6b016000 - 0x6b01e000, pointer @ 0x6b01df30 (Cookie OK)
State: Task (Ready)
Workbench [Workbench] (Ready)
Stack: 0x6b97c004 - 0x6b985ffc, pointer @ 0x6b985ea0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80008100
dopus_clock (Waiting)
Stack: 0x6576e000 - 0x65770000, pointer @ 0x6576fc70 (Cookie OK)
Stack: 0x624d5000 - 0x624d7000, pointer @ 0x624d6c70 (Cookie OK)
SabreMSN (Waiting)
Stack: 0x5ad91004 - 0x5ae2fffc, pointer @ 0x5ae2df50 (Cookie OK)
Signals: SigRec 0x7e001080, SigWait 0x00000100
ramlib (Waiting)
Stack: 0x6c327004 - 0x6c33fffc, pointer @ 0x6c33ff20 (Cookie OK)
Stack: 0x699b1004 - 0x699b8ffc, pointer @ 0x699b8f40 (Cookie OK)
MUI imagespace screen notify (Waiting)
Stack: 0x69d45004 - 0x69d4cffc, pointer @ 0x69d4cd10 (Cookie OK)
dopus_hotkeez (Waiting)
Stack: 0x5bba1000 - 0x5bba3000, pointer @ 0x5bba2f20 (Cookie OK)
TextEditor.mcc clipboard server (Waiting)
Stack: 0x684dc004 - 0x684ddffc, pointer @ 0x684ddf00 (Cookie OK)
NListtree.mcc clipboard server (Waiting)
Stack: 0x6929a004 - 0x6929bffc, pointer @ 0x6929bf00 (Cookie OK)
Stack: 0x6576c000 - 0x6576e000, pointer @ 0x6576df20 (Cookie OK)
BetterString.mcc clipboard server (Waiting)
Stack: 0x684d0004 - 0x684d1ffc, pointer @ 0x684d1ed0 (Cookie OK)
texteditor.gadget Clipboard Server (Waiting)
Stack: 0x69bc5004 - 0x69bddffc, pointer @ 0x69bddf00 (Cookie OK)
NList.mcc clipboard server (Waiting)
Stack: 0x6991e004 - 0x6991fffc, pointer @ 0x6991ff00 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x69e00004 - 0x69e09ffc, pointer @ 0x69e09f40 (Cookie OK)
Stack: 0x69e4a004 - 0x69e51ffc, pointer @ 0x69e51db0 (Cookie OK)
Stack: 0x69e90004 - 0x69e97ffc, pointer @ 0x69e97f00 (Cookie OK)
multiren (Ready)
Stack: 0x59000004 - 0x59007ffc, pointer @ 0x58ff9600 (Cookie OK)
Signals: SigRec 0x3e000000, SigWait 0x22000100
RinghioServer (Ready)
Stack: 0x6957e004 - 0x6959dffc, pointer @ 0x6959d370 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
TCP/IP Control (Ready)
Stack: 0x6c152004 - 0x6c161ffc, pointer @ 0x6c161dc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x50000100
AmiDock (Ready)
Stack: 0x697dd004 - 0x697ecffc, pointer @ 0x697ec930 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x00000100
OWB [OWB] (Ready)
Stack: 0x67ed9004 - 0x67fcdffc, pointer @ 0x67fcd440 (Cookie OK)
Signals: SigRec 0x00001080, SigWait 0x00000180
screenblanker.library timing dispatcher (Waiting)
Stack: 0x69690004 - 0x69697ffc, pointer @ 0x69697ea0 (Cookie OK)
AmIRC (Waiting)
Stack: 0x69281084 - 0x6928dfc4, pointer @ 0x6928dba0 (Cookie OK)
Signals: SigRec 0xbf00f080, SigWait 0x00000100
ftpd (Waiting)
Stack: 0x69e16004 - 0x69e1fffc, pointer @ 0x69e1f560 (Cookie OK)
Signals: SigRec 0xfc003080, SigWait 0x00000100
DirectoryOpus (Waiting)
Stack: 0x65846004 - 0x658c5ffc, pointer @ 0x658c3650 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x04000000
dopus_arbiter (Waiting)
Stack: 0x65778004 - 0x657f7ffc, pointer @ 0x657f7f00 (Cookie OK)
DRemind (Waiting)
Stack: 0x691f5004 - 0x691fcffc, pointer @ 0x686fd690 (Cookie OK)
Signals: SigRec 0xbe000000, SigWait 0x00000100
ARexx [] (Waiting)
Stack: 0x6850a004 - 0x68511ffc, pointer @ 0x68511e10 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x80000010
YAM (Waiting)
Stack: 0x66760004 - 0x6676fffc, pointer @ 0x6676f9c0 (Cookie OK)
Signals: SigRec 0x3facb000, SigWait 0x00000180
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x6c16e004 - 0x6c17dffc, pointer @ 0x6c17da00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
Stack: 0x5b760004 - 0x5b7dfffc, pointer @ 0x5b7df2b0 (Cookie OK)
Signals: SigRec 0x5c008000, SigWait 0x00000100
Stack: 0x62578004 - 0x625f7ffc, pointer @ 0x625f7f00 (Cookie OK)
Stack: 0x6c18e004 - 0x6c19dffc, pointer @ 0x6c19dde0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000100
MPlayer-GUI (Waiting)
Stack: 0x5b9db004 - 0x5b9e2ffc, pointer @ 0x5b9e2410 (Cookie OK)
Signals: SigRec 0xf6001002, SigWait 0x00000100
ContextMenus [] (Waiting)
Stack: 0x69678004 - 0x6967fffc, pointer @ 0x6967fc50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
Background CLI [ann] (Waiting)
Stack: 0x594db004 - 0x594e2ffc, pointer @ 0x594e2850 (Cookie OK)
Signals: SigRec 0xec000002, SigWait 0x00008100
Stack: 0x6be58000 - 0x6be58fa0, pointer @ 0x6be58f10 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x6bcd6004 - 0x6bcdfffc, pointer @ 0x6bcdff10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd82004 - 0x6fd89ffc, pointer @ 0x6fd89f00 (Cookie OK)
[OWB] IconDatabase (Waiting)
Stack: 0x67c90004 - 0x67d84ffc, pointer @ 0x67d84eb0 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000100
Background CLI [rx] (Waiting)
Stack: 0x68518004 - 0x6851fffc, pointer @ 0x6851fe20 (Cookie OK)
Background CLI [A-Progg:AmiVNC4/AmiVNC4] (Waiting)
Stack: 0x685fa004 - 0x68601ffc, pointer @ 0x68601530 (Cookie OK)
Signals: SigRec 0x00001080, SigWait 0x00000100
Background CLI [InterNet:AmiVNC4/AmiVNC4] (Waiting)
Stack: 0x68663004 - 0x6866affc, pointer @ 0x6866a520 (Cookie OK)
« IPrefs » (Waiting)
Stack: 0x6bee2004 - 0x6beebffc, pointer @ 0x6beeb530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000000
ASYNCWB (Waiting)
Stack: 0x6977b004 - 0x69782ffc, pointer @ 0x69782e70 (Cookie OK)
Macc (Waiting)
Stack: 0x6a701004 - 0x6a708ffc, pointer @ 0x6a708d50 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x00000100
RAWBInfo (Waiting)
Stack: 0x6970d004 - 0x69714ffc, pointer @ 0x69714ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x6976f004 - 0x69776ffc, pointer @ 0x69776dc0 (Cookie OK)
Background CLI [KeepAHIOpen] (Waiting)
Stack: 0x6b9d7004 - 0x6b9e6ffc, pointer @ 0x6b9e6b80 (Cookie OK)
Signals: SigRec 0x00001000, SigWait 0x80000000
ConClip (Waiting)
Stack: 0x6ba7f004 - 0x6ba86ffc, pointer @ 0x6ba86eb0 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x6bb8e004 - 0x6bb95ffc, pointer @ 0x6bb95ee0 (Cookie OK)
DST watcher (Waiting)
Stack: 0x6bde0004 - 0x6bde7ffc, pointer @ 0x6bde7f20 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x6c1aa004 - 0x6c1b9ffc, pointer @ 0x6c1b9f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd9a004 - 0x6fda1ffc, pointer @ 0x6fda1f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd8e004 - 0x6fd95ffc, pointer @ 0x6fd95f00 (Cookie OK)
ramlib.support (Waiting)
Stack: 0x6c344004 - 0x6c35cffc, pointer @ 0x6c35cf00 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000000
dos_signal_server (Waiting)
Stack: 0x6ff25004 - 0x6ff26ffc, pointer @ 0x6ff26f10 (Cookie OK)
Signals: SigRec 0x0000e000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x6c10c004 - 0x6c113ffc, pointer @ 0x6c113da0 (Cookie OK)
AmigaAMP DrawTask (Ready)
Stack: 0x5bf77004 - 0x5bf7effc, pointer @ 0x5bf7eee0 (Cookie OK)
Signals: SigRec 0xc0001000, SigWait 0xc0000000
LimpidClock (Ready)
Stack: 0x69c7e004 - 0x69c85ffc, pointer @ 0x69c84d30 (Cookie OK)
Signals: SigRec 0xf0001000, SigWait 0x00000100
Sound_ObjectHandler (Waiting)
Stack: 0x5a996004 - 0x5aa34ffc, pointer @ 0x5aa34eb0 (Cookie OK)
Signals: SigRec 0x4000f000, SigWait 0x00000100
Stack: 0x5ac5d004 - 0x5acfbffc, pointer @ 0x5acfbeb0 (Cookie OK)
Stack: 0x5ab21004 - 0x5abbfffc, pointer @ 0x5abbfeb0 (Cookie OK)
Stack: 0x5b281004 - 0x5b28dffc, pointer @ 0x5b28deb0 (Cookie OK)
Stack: 0x5b401004 - 0x5b40dffc, pointer @ 0x5b40deb0 (Cookie OK)
Stack: 0x5b58a004 - 0x5b596ffc, pointer @ 0x5b596eb0 (Cookie OK)
Stack: 0x5b1b1004 - 0x5b1bdffc, pointer @ 0x5b1bdeb0 (Cookie OK)
Stack: 0x5b349004 - 0x5b355ffc, pointer @ 0x5b355eb0 (Cookie OK)
Stack: 0x5b4c9004 - 0x5b4d5ffc, pointer @ 0x5b4d5eb0 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x6ff2b004 - 0x6ff2cffc, pointer @ 0x6ff2ccc0 (Cookie OK)
idle.task (Ready)
Stack: 0x6ff86000 - 0x6ff87000, pointer @ 0x6ff86fd0 (Cookie OK)
State: Task (Ready)
Hypex
Re: EHCI task crashes while copying from a µSD card.
Post by Hypex »
Hey that looks like my log! :-)
Yeah I use the hidden function a lot. Handy for logs.
ssolie
Post by ssolie »
Hypex wrote:Hey that looks like my log! :-)
I hope you filed a bug report and attached your log... ;-)
Actually, I edited his posting and added the hidden tag. I left in the original complaint though.
cha05e90
Post by cha05e90 »
Deniil wrote:Something else that happens even more often is that DOS freezes for about 10 seconds during a transfer (file copy). Everything that accesses DOS, like playing music (after IO buffer runs out) and the USB transfer itself then halts, and then continues normally after 10 or so seconds. I find this behaviour very wierd. Input and intuition does not hang during this period.
Could you do me a biiiiiiiiig favour? Could you try do make a "dumpdebugbuffer" right after this freezes? Please!!!!
Hypex
Post by Hypex »
Actually I attached it to my original EHCI report but it may have been missed. Haven't got it onto Bugzilla yet. Have had to go out evey night this week.
