Kernel 4.9
Re: Kernel 4.9
Spectre660 wrote:Hi Christian,
It is booting.
Regards
Julian
Hi Julian,
Many thanks for testing! :-)
Re: Kernel 4.9
I have recently released a new version of the stable longterm kernel 4.9 with the BFQ I/O scheduler for the AmigaOne X5000 and X1000.
Download: vmlinux-4.9.62-AmigaONE_X1000_X5000.tar.gz
Screenshot of ubuntu MATE 16.04.3 LTS PowerPC with Mesa 17.2.4 and with the new stable longterm kernel 4.9.62:
You can also see Xonotic from Casey's new repository in the screenshot. :-)
Re: Kernel 4.9
I released a new version of the stable longterm kernel 4.9 with the BFQ I/O scheduler for the AmigaOne X5000 and X1000 today.
Download: vmlinux-4.9.63-AmigaONE_X1000_X5000.tar.gz
Re: Kernel 4.9
Download: vmlinux-4.9.64-AmigaONE_X1000_X5000.tar.gz
Re: Kernel 4.9
I cross compiled the stable longterm kernel 4.9.65 on my Lubuntu 16.04.3 LTS x86-64 for the X5000 and X1000 today. :-)
Could you please test this cross compiled kernel on your AmigaOne X1000 and X5000? I'd like to know if it works.
Download: vmlinux-4.9.65-AmigaONE_X1000_X5000.tar.gz
Cross compiling instructions:
System requirements: Ubuntu 14.04 x86 or higher
  1. Install the toolchain with the following commands:
    sudo apt-get install gcc-powerpc-linux-gnu
    sudo apt-get install build-essential
    sudo apt-get install libncurses5-dev
    sudo apt-get install u-boot-tools
  2. Download the stable longterm kernel 4.9.65
  3. Unpack the kernel archive
  4. Rename the directory for the patches:
    mv linux-4.9.65 a
    For the AmigaOne X1000:
  5. Patch the kernel source code with the Nemo patch:
    patch -p0 < nemo_4.9-8.patch
    For the AmigaOne X5000:
  6. Patch the kernel source code with the Cyrus patch:
    patch -p0 < cyrus_4.9-1.patch
    For the AmigaOne X5000 and X1000:
  7. Patch the kernel source code with the BFQ patches:
    patch -p0 < 0001-block-cgroups-kconfig-build-bits-for-BFQ-v7r11-4.5.0.patch
    patch -p0 < 0002-block-introduce-the-BFQ-v7r11-I-O-sched-for-4.5.0.patch
    patch -p0 < 0003-block-bfq-add-Early-Queue-Merge-EQM-to-BFQ-v7r11-for.patch
    patch -p0 < 0004-Turn-into-BFQ-v8r7-for-4.9.0.patch
  8. Copy the additional files from the directory b to a
  9. Copy the old kernel config file to the a directory
  10. Change to the directory a
  11. Create a new kernel config file based on the old kernel config file:
  12. Compile the Linux kernel:
    make CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc vmlinux
    make CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc uImage
  13. With file you can check the kernel.
    file vmlinux
    vmlinux: ELF 64-bit MSB executable, 64-bit PowerPC or cisco 7500, version 1 (SYSV), statically linked, BuildID[sha1]=4eeead69178e4a309ec9719c363d92564e011b74, not stripped
    file uImage
    uImage: u-boot legacy uImage, Linux-4.9.65_A-EON_AmigaOneX5000\037\213\010, Linux/PowerPC, OS Kernel Image (gzip), 9676429 bytes, Sat Dec 23 00:38:21 2017, Load Address: 0x00000000, Entry Point: 0x00000000, Header CRC: 0xC237FC8D, Data CRC: 0xF45AC18E
  14. Compile the Linux kernel modules:
    make CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc modules
  15. Install the Linux kernel modules:
    sudo make CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc modules_install
    You can get the kernel modules from the directory /lib/modules.
Please test the cross compiled kernel.
Re: Kernel 4.9
Hello Everyone,
Here is a new version of the stable longterm kernel 4.9 with the BFQ I/O scheduler for the AmigaOne X5000 and X1000. :-)
Download: vmlinux-4.9.66-AmigaONE_X1000_X5000.tar.gz
BTW, I was able to boot SliTaz PPC on a virtual QEMU machine with a P5020 CPU (one e5500 core).
Screenshot of Debian Sid PowerPC with the stable longterm kernel 4.9.66 and with SliTaz PPC on a virtual P5020 system:
Ribdevil
Re: Kernel 4.9
Post by Ribdevil »
Hi.
Happy Holidays and New Year.
Where can I find an easy guide to install qemu ?
Virginio
Re: Kernel 4.9
Ribdevil wrote:Hi.
Virginio
Hi Virginio,
happy holidays and a happy New Year for you too. :-)
You can install QEMU with the following command on Ubuntu:
sudo apt-get install qemu-system
Ribdevil
Re: Kernel 4.9
Post by Ribdevil »
Thanks Christian
Virginio
Re: Kernel 4.9
I cross compiled a new version of the stable longterm kernel 4.9 with the BFQ I/O scheduler for the AmigaOne X5000 and X1000 today.
Download: vmlinux-4.9.67-AmigaONE_X1000_X5000.tar.gz
