ubuntu MATE 16.04.1 LTS Live USB
Re: ubuntu MATE 16.04.1 LTS Live USB
dd if=/dev/loop0 of=/dev/<your partition>
Got it done now... Seems to work ok, and now I also got rid of the Bluetooth error message which hounted the installation I made from the LIve USB. Thank you very much! :-)
A couple of further questions... I created a new account, but how can I make it 'default', so that Ubuntu would always boot using that account? In 'users and accounts' there was no 'tick' to choose that.
A new user account type seems to be by default 'custom'. If I give in the advanced settings to that user all the possible rights listed there, does it have the same rights as a user changed to 'administrator'? Or does the 'administrator' have some rights that the 'custom' user cannot have?
Spectre recommended to update right away this installation as it is rather old... Should I take all the updates there are available, or choose only some of them (if there are some which may mix the installation)?
Spectre660 wrote: Option 3 for installing Ubuntu-Mate 16.04
A usb .img that can be booted and copied using dd to a harddrive partition .
Image is compressed as 7z so needs to be extracted before writing .
has a username of Amigaone with password of amigaone .
Once installed you will need to update as it uses the first version of the Ubuntu-Mate .
no live user on this one.
should upload a newer version but it takes about 12 hours with my connection's upload speed .
https://www.dropbox.com/s/4r477z1kg57hi ... mg.7z?dl=0
I tried now to update this Ubuntu 16.04.3 installation I made earlier from the image above... Only a partial update was possible (is that normal?), and downloading the packages (c. 550MB) was succesful. During installation there was first a message that 'man-db' was not installed properly, and then a few minutes later the installation crashed Ubuntu totally (the last message was 'Preparing to configure fonts.-noto-cjk...').
Now the installation is broken, it cannot open the desktop anymore... Probably not possible to rescue it anymore as the installation process was interrupted...?
Updating this message...
Something very strange happened! After a few reboots I finally got the login window, from where the system was able to reach a somewhat strangely looking desktop (most icon pictures were missing, the backround was different etc.). When I opened the softwarer updater, it started to 'confiiguring' an endless list of software items... When it had finished, I run the updfater again, and it reported that all packages are already downloaded, and then it continued to install a few packages (stored who nows where). After all that was finished, I rebooted... And booting advanced as it usually does, and I got the normal desktop again!
Running again the updater just gave the message 'system is up to date'.
I am very, very surpriced... Is the recovery capability of Ubuntu really this high, or may this installation still be 'broken' under the surface...? Is there a way to check it?
softwarefailure
Post by softwarefailure »
So where have all the download links to Ubuntu for the X5000 gone? I wanted to install Ubuntu on my X5000 according to the following tutorial:
https://amigax5000.blog/2017/07/23/inst ... the-x5000/
...but the links to the image files are all dead. Also the links to the image files in this thread seem to be dead. So where can I download Ubuntu for the X5000?
Best installation option for X5000 is via net installer (Based on the Debian alternate installer) rather than the pre-installed .img.
See the following thread for links.
http://forum.hyperion-entertainment.biz ... 776#p41558
softwarefailure wrote:So where have all the download links to Ubuntu for the X5000 gone? I wanted to install Ubuntu on my X5000 according to the following tutorial:
softwarefailure
Ok, I've now arrived at the network configuration screen. Two questions about that:
1) Where does the network cable go? There are two connectors for that on my X5000. One is at the top next to the USB ports and the other is below the sound board, probably from an additional network card inside the X5000.
2) What do I have to select as the primary network interface? The options are: dummy0, ip6_vti0, ip6tn10, ip_vti0, tun10.
Use the connection for the additional network card inside the X5000.
The description of this card should show up once connected in the primary network options .
The Built in ethernet currently is only supported by U-boot. Not Linux or AmigaOS 4.1 .
http://forum.hyperion-entertainment.biz ... 715#p41151
softwarefailure wrote:Ok, I've now arrived at the network configuration screen. Two questions about that:
softwarefailure
Spectre660 wrote: The description of this card should show up once connected in the primary network options .
Well, it doesn't. The only cards listed are: dummy0, ip6_vti0, ip6tn10, ip_vti0, tun10. And none of them works :-( It always fails during DHCP configuration although my network is configured to use DHCP and this works fine with all my other systems. So it's clearly an X5000 issue. Any other ideas that I could try?
Does it work under AmigaOS 4.1 ?
Also you can check the System Info option in U-Boot to see if it is recognized .
softwarefailure
In System Info it says NULL for "MAC Address" and "MAC Address 2" so I guess there's something wrong with the network card? What should I do now? Contact my dealer about it?
