Behavior of environmental variables depending on name
JosDuchIt
Post by JosDuchIt »
environmental variables are said to be used in scripts when preceded with a $ sign
If the name of the variable contains a "." dot the results are not as expected.
Is there a reason or could this be corrected?
6.Env:> setenv y "value"
6.Env:> getenv y
value
6.Env:> echo $y
value
6.Env:> type y
value6.Env:>
6.Env> setenv .y "value"
6.Env:> getenv .y
value
6.Env:> echo $.y
$.y  ///???
6.Env:> type .y
value6.Env:>
6.Env:> setenv y.1 "value"
6.Env:> getenv y.1
value
6.Env:> echo $y.1
value.1 /// ?????
6.Env:> type y.1
value6.Env:>
6.Env:> setenv .y.1 "value"
6.Env:> getenv .y.1
value
6.Env:> echo $.y.1
$.y.1 ///???
6.Env:> type .y.1
value6.Env:>
salass00
Re: Behavior of environmental variables depending on name
Post by salass00 »
For weird variable names like that or other situations were AmigaDOS has trouble identifying where the variable name starts and ends you should use curly braces:
8.RAM Disk:> setenv .y. "Hello World"
8.RAM Disk:> echo ${.y.}
Hello World
8.RAM Disk:>
JosDuchIt
Post by JosDuchIt »
Thanks a lot.
Is this documented somewhere?
You can also start your script with something like:
.dot !
"." is a special character in AmigaDOS scripts.
Daedalus
Post by Daedalus »
JosDuchIt wrote:Is this documented somewhere?
I don't think it's specifically documented, but in general it's always been the case that special characters have to be treated carefully in AmigaDOS, especially in scripts. The documentation here talks about substitution of special characters in scripts, specifically brackets and dots.
