I use the stable longterm kernel 4.9.6 and sometimes I test it with a RC of kernel 4.10.musa wrote:Hi Christian
Can you tell me what kernel you use to start fedora
thanks
Fedora 25 ppc64
Re: Fedora 25 ppc64
Re: Fedora 25 ppc64
thanksxeno74 wrote:I use the stable longterm kernel 4.9.6 and sometimes I test it with a RC of kernel 4.10.musa wrote:Hi Christian
thanks
ok I use 4.9.5 but I will try 4.9.6 and see if it helps.
Re: Fedora 25 ppc64
Hi Christian
Earlier in this thread you said:
Alex figured out that the libmozjs-17.0.so is responsible for the polkitd issue. He patched the libmozjs-17.0.so. Fedora 25 works really better with Alex's patched libmozjs-17.0.so.
could it be that it's the same problem I have now? This solution is overwritten when I upgrade I think
Re: Fedora 25 ppc64
Hi Musa,musa wrote:Hi Christian
I am sorry I don't know because I don't have this problem. Could you please try out Alex's patched libmozjs-17.0.so? Maybe you're right.
Re: Fedora 25 ppc64
xeno74 wrote:Hi Musa,musa wrote:Hi Christian
Yes i find it in downloads but what do I do with it
Re: Fedora 25 ppc64
Please replace the libmozjs-17.0.so in /usr/lib64 and in /lib64.musa wrote: Yes i find it in downloads but what do I do with it
# cp libmozjs-17.0.so /usr/lib64Code: Select all
# cp libmozjs-17.0.so /lib64http://www.amigalinux.org
Re: Fedora 25 ppc64
yes it works. reinstall systemd and polkit and replaced libmozjs-17.0.so. all bugs are gone. I am happy because I have been very happy for Fedora. Good weekend and thanks for the helpxeno74 wrote:Please replace the libmozjs-17.0.so in /usr/lib64 and in /lib64.musa wrote: Yes i find it in downloads but what do I do with it
Re: Fedora 25 ppc64
Awesome!musa wrote: yes it works. reinstall systemd and polkit and replaced libmozjs-17.0.so. all bugs are gone. I am happy because I have been very happy for Fedora. Good weekend and thanks for the help
Re: Fedora 25 ppc64
Hi Musa,musa wrote:I get mine here http://rpmfind.net/linux/rpm2html/searc ... ry=firefoxxeno74 wrote:
Well done!
Where can I download the Firefox package?
Did you install the Fedora 26 RPM package of Firefox 51.0? I haven't found any Fedora 25 RPM package of Firefox 51.0. The latest Firefox version is the 50.1.0 in the Fedora 25 repositories.
Re: Fedora 25 ppc64
Hi Christianxeno74 wrote:
Hi Musa,
I install firefox-50.1.0-1.fc25.ppc64.rpm .
I succeeded to install a printer on Fedora. I had to instal cups to get it to work. sudo dnf install cups
I realy like fedora
