Fedora 25 ppc64
Re: Fedora 25 ppc64
musa wrote:If I did not upgrade package crypto policies, it is possible for me to upgrade fedora without fedora afterwards fails. I had to install firefox 50.1.0 separate from the rpm package. Also, I have changed the start to graphical login. I am very positively surprised by the possibilities in Fedora.
Well done! :-)
Where can I download the Firefox package?
Re: Fedora 25 ppc64
Well done! :-)
I get mine here http://rpmfind.net/linux/rpm2html/searc ... ry=firefox
I have a little problem with Mesa
libGL error: Version 7 or imageFromFds image extension not found
libGL error: failed to load driver: r600
OpenGL vendor string: X.Org
OpenGL renderer string: Gallium 0.4 on AMD BARTS (DRM 2.48.0 / 4.9.5_A-EON_AmigaONE_X1000_Nemo, LLVM 3
Re: Fedora 25 ppc64
musa wrote: I get mine here http://rpmfind.net/linux/rpm2html/searc ... ry=firefox
Maybe a package is missing. I will update too.
Re: Fedora 25 ppc64
Hi Musa,
I have recently updated my Fedora 25 Server PPC64. I have no problems with the crypto policies but I can't set up a background image for the MATE desktop. The desktop is always black. I have seen in your screenshot that you don't have any problems with set up a background image. I don't have any problems with Mesa. It seems our installations are different. I don't know why. Firefox was updated automatically.
Screenshot of my updated Fedora 25 Server PPC64:
Many thanks for testing Fedora 25 PPC64!
Re: Fedora 25 ppc64
Hi Christian
I can not select update all because of crypto policies and therefore I did not get firefox automatic. I installed therefore from file.
I also have black screen, but installed compiz fusion. Here I choose mate, compiz or openbox as the windows manager. Mate gives black screen Compix gives errors in the way the desktop is drawn on (Slooow update). Openbox allows you to select desktop image. It is either an error in mate or compiz.
Which version is Mesa do you have.
Re: Fedora 25 ppc64
musa wrote:Hi Christian
Mesa 13.0.3
Re: Fedora 25 ppc64
Hi Christian
New info. in compiz config select wallpaper and enable. open setting and select a photo and Close. In compiz fusion choose compiz as windoes manager and close. stable desktop with new photo.
I will try to update manuel to mesa 13
Re: Fedora 25 ppc64
Hi Musa,
Many thanks for your hints. It works fantastic! (see screenshot)
Re: Fedora 25 ppc64
Hi Musa,
Yes its fantastic :) but mesa 13 fix my driver driver problem but install crypto policies, and that means I no network yum can not start and everything is very slowly. Trying to downgrade but it does not seem to work. over again :(
Re: Fedora 25 ppc64
Hi Christian
Can you tell me what kernel you use to start fedora
thanks
