Ubuntu LiR7 250X graphics card
SteveH
Post by SteveH »
I've been trying to play with the Ubuntu live remix DVD after an absence of some months. In the meantime, I've upgraded my graphics card to an R7 250X - and now I only get a blank screen after the Ubuntu loading screen. (The version of Ubuntu I'm trying to use is 12.04 LTS).
Is this a known problem and, if so, what flavour(s) of Linux will work with my card?
Steve
Re: Ubuntu LiR7 250X graphics card
SteveH wrote:I've been trying to play with the Ubuntu live remix DVD after an absence of some months. In the meantime, I've upgraded my graphics card to an R7 250X - and now I only get a blank screen after the Ubuntu loading screen. (The version of Ubuntu I'm trying to use is 12.04 LTS).
Steve
Hi Steve,
You could try to boot the A-EON Live Remix DVD with the kernel 4.0.7 if you like.
Download: linux-4.0.7-livedvd.tar.bz2
Please note Jdupuis' explanation:
jdupuis wrote:Hi Christian,
Performing a 12.04 install with DVD and Kernel 4.0.7 led me to a riddle. I have tested this and determined repeatability. Know that this , at the least, gets Ubuntu 12.04 DVD loaded for an install. My finding using 4.0.7 on CF Card:
1st CFE> ramdisk -addr=0x24000000 -fs-iso atapi0.1:casper/powerpc64/initrd ( after pressing ENTER, hit up arrow to re-display statement and ENTER again, this time no error reading )
2nd CFE> setenv bootargs "root=/dev/ramdisk file-/cdrom/preseed/ubuntu.seed boot=casper - ( hit ENTER this forces verbose ) however, it seems that certain things are not started, but, it avoids the Ubuntu splash screen that locks up booting )
3rd CFE> boot -elf -noints -fatfs cf0:vmlinux-4.0.7
As stated, this method has given me successful and consistent boots with the DVD and at least provides the install capability. I am just puzzled that the Ubuntu splash screen will freeze booting everytime when booting with normal CFE Command line entries.
Booting my Ubuntu install on "sdc1", I have discovered the same thing.
1st CFE> setenv bootargs "root=/dev/sdc1 - ( ENTER ) goes into verbose
2nd CFE> boot -elf -noints -fatfs cf0:vmlinux-3.17 worked! 4.1.20 worked!
Rasterizer graphics only. No SuperTuxKart, glxgears sloow, but, the updates work and this gives a Linux install as a base to get Ubuntu Mate 16.04 installed for those with an R7 250X.
Just wondering why it works like this. I guess is what puzzles me. Just reporting an interesting finding.
Cheers!!
John
SteveH
Post by SteveH »
Hi Steve,
Thanks, I'll give that a try. Are there any other distro's that are known to work with my card?
On an unrelated topic - I'm eventually going to boot into Linux from CF card. Is the Linux side able to see the CF card once booted (as it's a 8Gb card and so will have an unused 4Gb once formatted with FAT) or is it only visible to CFE?
Steve
SteveH wrote: Thanks, I'll give that a try. Are there any other distro's that are known to work with my card?
Hi Steve,
Maybe ubuntu MATE but it isn't easy to install it.
SteveH wrote: On an unrelated topic - I'm eventually going to boot into Linux from CF card. Is the Linux side able to see the CF card once booted (as it's a 8Gb card and so will have an unused 4Gb once formatted with FAT) or is it only visible to CFE?
Yes, it's visible on Linux. :-)
SteveH
Post by SteveH »
Hi Steve,
The 4.0.7 kernel has worked for me - I'm now booting into Ubuntu.
Thanks!
SteveH wrote:
Hi Steve,
Thanks!
Thanks for testing! :-)
