[_impl_KMemCacheFree] *** Warning: Freeing buffer to foreign
javierdlr
Post by javierdlr »
Is it a bug in my snes9xgui code or....
[_impl_KMemCacheFree] *** Warning: Freeing buffer to foreign cache
[_impl_KMemCacheFree] ** Warning: Task snes9xGUI.debug freeing object 0x609B5F98 to wrong cache primary heap emu cache 4928 (not compact, hash 27)
[_impl_KMemCacheFree] ** Warning: Task snes9xGUI.debug freeing object 0x5D526338 to wrong cache primary heap emu cache 4928 (not compact, hash 29)
[_impl_KMemCacheFree] ** Warning: Task snes9xGUI.debug freeing object 0x495D91C8 to wrong cache primary heap emu cache 4928 (not compact, hash 14)
Object *newobj = NULL;
// Create/set new preview (, dispose old), "reassign" new and refresh window/pagetab
if( (newobj=IIntuition->NewObject(BitMapClass, NULL, //"bitmap.image",
                                  IA_Scalable,TRUE, BITMAP_Screen,screen,
                                  BITMAP_SourceFile,filename, TAG_DONE)) )
 ILayout->SetPageGadgetAttrs(GAD(OID_PREVIEW_BTN), OBJ(OID_GENERAL), pw,
                             NULL, BUTTON_RenderImage,newobj, TAG_DONE); // pagetab
 IIntuition->DisposeObject( OBJ(OID_PREVIEW_IMG) );
 OBJ(OID_PREVIEW_IMG) = newobj;
else { ... }
ILayout->RefreshPageGadget(GAD(OID_PREVIEW_BTN), OBJ(OID_GENERAL), pw, NULL);
TIA
AOS4.1/SAM460ex/PPC460EX-1155MHZ/2048MB/RadeonHD6570/SSD120GB/DVDRW :-P
TSK
Location: Home land of Santa C., sauna, sisu and salmiakki
Re: [_impl_KMemCacheFree] *** Warning: Freeing buffer to for
Post by TSK »
I asked the kernel guy what such error message from another software means and he said it's usually a buffer overrun/underrun.
Keep the party going !
javierdlr
Post by javierdlr »
TSK wrote:I asked the kernel guy what such error message from another software means and he said it's usually a buffer overrun/underrun.
ok. thx. But is problem of my c code (solved by raising stack value), or is it some internal "problem" (exec, intuition, classes,...)
TSK
Post by TSK »
Mr. Frieden said the kernel doesn't have such problems so the problem must be on an application side. Your code in the first post looks good. Are you sure that code part generates those error messages and it's not some other part of the code causing it ?
javierdlr
Re: [_impl_KMemCacheFree] *** Warning: Freeing buf..(SOLVED)
Post by javierdlr »
TSK wrote:Mr. Frieden said the kernel doesn't have such problems so the problem must be on an application side. Your code in the first post looks good. Are you sure that code part generates those error messages and it's not some other part of the code causing it ?
thx, will try to do some more tests (or maybe a simplifly the gui and see what happens.)
EDIT: find culprit, was allocating/freeing unneeded variables/objects, once removed such allocate()/free() no more warnings. THX
