openSUSE Tumbleweed
Re: openSUSE Tumbleweed
I was able to update openSUSE Tumbleweed PowerPC64 to version 20201002 today.
Be aware, that openSUSE is experimental and isn't supported. openSUSE for the AmigaOne X1000 and X5000 is alpha software! It's only for testing and tinkering!
I was able to copy the complete openSUSE partition with dd and netcat via network from the X1000 to the X5000 today.
Commands:
X5000:
# netcat –l -p 4444 | dd of=/dev/sda3
X1000:
# dd if=/dev/sdb6 | netcat 192.168.178.59 4444
X1000: dd output:
32323584+0 records in
32323584+0 records out
16549675008 bytes (17 GB, 15 GiB) copied, 1412,44 s, 11,7 MB/s
X5000: dd output:
23879952+10266507 records in
16549675008 bytes (17 GB, 15 GiB) copied, 1487.5 s, 11.1 MB/s
X5000:
e2fsck -f /dev/sda3
Output:
e2fsck 1.42.13 (17-May-2015)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
openSUSE: 456457/1011840 files (0.5% non-contiguous), 2954960/4040448 blocks
X5000:
# resize2fs /dev/sda3
Output:
resize2fs 1.42.13 (17-May-2015)
Resizing the filesystem on /dev/sda3 to 90789888 (4k) blocks.
The filesystem on /dev/sda3 is now 90789888 (4k) blocks long.
Issue: Xorg doesn't start because libLLVM.so.10 isn't compatible with the P50x0 CPUs.
Solution:
Please boot to the runlevel 3 with the boot argument "3":
setenv bootargs root=/dev/sda 3
Login as "root" (password: amigaone) and rename the libLLVM.so.10 to libLLVM.so.10.bak with the following command:
mv /usr/lib64/libLLVM.so.10 /usr/lib64/libLLVM.so.10.bak
After that you can start Xorg with "startx". Unfortunately XFCE and MATE don't work on the X5000 but you can use FVWM instead.
