openSUSE Tumbleweed
Re: openSUSE Tumbleweed
Here you are:
/etc/zypp/repos.d
file repo-oss.repo:
[repo-oss]
name=repo-oss
enabled=1
autorefresh=1
baseurl=https://download.opensuse.org/ports/ppc/tumbleweed/repo/oss
path=/
type=rpm-md
keeppackages=0
file repo-non-oss.repo:
[repo-non-oss]
name=repo-non-oss
enabled=1
autorefresh=1
baseurl=https://download.opensuse.org/ports/ppc/tumbleweed/repo/non-oss
path=/
type=yast2
keeppackages=0
file repo-debug.repo:
[repo-debug]
name=repo-debug
enabled=1
autorefresh=1
baseurl=https://download.opensuse.org/ports/ppc/tumbleweed/repo/debug
path=/
type=yast2
keeppackages=0
Hi all,
I created with dd an img of my openSUSE Tumbleweed 20190521 PPC64 installation today.
Be aware, that openSUSE is experimental and isn't supported. openSUSE for the X1000 and X5000 is alpha software! It's only for testing and tinkering!
Download: openSUSE_Tumbleweed_20190521_ppc64.img.tar.gz
Users:
root (password "amigaone")
Screenshot:
sailorMH
Post by sailorMH »
xeno74 wrote: I created with dd an img of my openSUSE Tumbleweed 20190521 PPC64 installation today.
Hi xeno74,
I will gladly try it. Please, with southern island card is the same issue?
Need I rename the libglamoregl.so?
thanks!
Pegasos 2, Sam440ep-flex, AmigaOne X1000, Powebook G4, iMac G5, Powermac G5 Quad
MorphOS, AmigaOS, linux: MintPPC 11, Debian, Ubuntu ..., MacOS X
Hi Christian I found the repos but at that time my upgrade was broken. I therefore chose the easy solution and use your img file. I am now in the process of installing the programs I need.
All working fine at this time.
Thanks for the help
sailorMH wrote: Hi xeno74,
thanks!
Yes, you need to rename the libglamoregl.so if you use a SI graphics card.
sudo mv /usr/lib64/xorg/modules/libglamoregl.so /usr/lib64/xorg/modules/libglamoregl.so.bak
Thanks for the hint! :-)
musa wrote:Hi Christian I found the repos but at that time my upgrade was broken. I therefore chose the easy solution and use your img file. I am now in the process of installing the programs I need.
Thanks for the help
Hi Musa,
Please let me know if there are any problems. Please also post a screenshot from your openSUSE desktop.
Hi Musa,
Hi Christian. I install Mate desktop . Install compiz but lose windows decorations when use it as windows manager.
Has Suse no version of libreoffice?
musa wrote: Hi Christian. I install Mate desktop . Install compiz but lose windows decorations when use it as windows manager.
Hi Musa,
Many thanks for testing the openSUSE Tumbleweed 20190521 PPC64 img and thanks a lot for the screenshot! :-)
You're right. There isn't LibreOffice available for openSUSE Tumbleweed but you can install OpenOffice.
Hi Musa,
Hi Christian . I can't see any installation packages for openoffice.
I can see Abiword
I have noticed that I can only cook out but do not restart or turn off the computer.
If I try in a terminal to write sudo caja, the following happens
I write my root password and get this message
Could not parse argument: Cannot open terminal
in the beginning i could well start caja as root but no more. Are there any problems with rights
musa wrote: Hi Christian . I can't see any installation packages for openoffice.
I can see Abiword
Yes, you’re right because of OpenOffice. There are only debug packages of OpenOffice available. I don’t use Caja. Please try it with /usr/bin/xdg-su -c caja.
I can reboot and shutdown the X1000 with XFCE. Can you shutdown or reboot your X1000 with MATE?
