Keyboard and Mouse not working
AlfredOne
Post by AlfredOne »
Hi guys!
I can't understand why my keyboard and mouse work with CFE but don't work 99% of times on linux.
I tried all kernels: 3.18 , 4.1.xxx , 4.4.xxx , 4.5.xxx and a lot of ubuntu mate installation releases. All the same: sometimes (very rarely) mouse and keyboard are recognized and i've managed to install linux.
But the next time i boot, i can only look at the login window and at the running clock on the menu bar. The mouse led is switched off permanently and no click or movements are active, keyboard is off too.
I tried to connect by ssh but ssh service seems off to me and connection is refused.
Where is the problem?
thanks
Amiga500 Kickstart1.3
AmigaONE X1000 - 2GB RAM
  • Radeon R9-280X 3GB
  • Radeon HIS4670 1GB DDR3
  • Radeon RX550
My site: https://project4a.eu
Re: Keyboard and Mouse not working
AlfredOne wrote:Hi guys!
thanks
Could you test it with another mouse and keyboard, please?
AlfredOne
Post by AlfredOne »
xeno74 wrote:Could you test it with another mouse and keyboard, please?
I tested both the standard A1-X1000 mouse/keyboard, and two generic mouse/keyboard.
  • Radeon RX550
Do you use a xorg.conf for X11? Maybe the configuration of the xorg.conf is not correct.
AlfredOne
Post by AlfredOne »
The problem is with installation procedure too.
  • Radeon RX550
Do the keyboard and mouse work with OS4.1?
AlfredOne
Post by AlfredOne »
Yes, always.
  • Radeon RX550
vox
Post by vox »
thanks
Stupidest question ever asked: is the KEYBOARD attached as explained in the manual? Upper right corner back USB if I remember correctly?
That is only way to use it in CFE and helps Linux see it. AmigaOS after Kickstar load gets whatever there is.
Yes, always.
Do you use a USB hub?
AlfredOne
Post by AlfredOne »
i tried both with and without USB hub but the problem is the same.
N.B.: i just booted by USB Image "Ubuntu-Mate_16.04-X1000-SI.img.7z" and mouse and keyboard work fine!.
  • Radeon RX550
