Kernel 4.4
Re: Kernel 4.4
zzd10h wrote:Yes, 4.4.4-2 don't boot
this one http://forum.hyperion-entertainment.biz ... =20#p36135
So latest working 4.4 kernel for me is 4.4.3
this one
http://forum.hyperion-entertainment.biz ... =10#p36015
Could you confirm that srtest problem is the same one ?
If yes, the problem could be really the newest Radeon GFX card.
I think the problem is the new firmware package (firmware-amd-graphics (20151018-2). I will release the Alpha9 with the old firmwares (firmware-nonfree_0.44) in the Kernel 4.5 thread.
zzd10h and Srtest, please test the Alpha9.
Re: Kernel 4.4
mechanic wrote:@xeno74
Will you be applying the byte swap code to the 4.4 kernel and patch file?
Yes, I will do it next week.
Mechanic, sorry, it doesn't make any sense to build a new kernel 4.4 final with the byte swap code because there are some problems with some HD7750 and 7970 graphics cards. Please look in the Kernel 4.5 thread. I am sorry. :-(
Re: Kernel 4.4
Spectre660 released a new stable version of the kernel 4.4 yesterday.
Download: vmlinux-4.4.3-AmigaONE_X1000.tar.gz
Re: Kernel 4.4
Spectre660 has recently released the kernel 4.4.4 for the AmigaONE X1000.
New: ChangeLog-4.4.4
Download: vmlinux-4.4.4-AmigaONE_X1000.tar.gz
This kernel is different to my kernels and this is really fantastic. The kernel messages output use an other format (better format) and he added more kernel modules.
marcus
Re: Kernel 4.4
Post by marcus »
The nemo_4.4.patch included in the Spectre660 release seems to be missing the ethernet fix (arch/powerpc/Kconfig and arch/powerpc/kernel/dma.c). I built a 4.4.5 kernel using this patch and on-board ethernet was not working.
Will try again after manually applying the ethernet patch.
marcus
Re: Kernel 4.4
Post by marcus »
marcus wrote:Will try again after manually applying the ethernet patch.
Yup, after applying the changes from nemo_4.4-12.patch to these files, ethernet is now working again.
Re: Kernel 4.4
Thank you for your hint! :-)
Re: Kernel 4.4
I released the stable longterm kernels 4.4.189 and 4.4.196 for the Tabor board today.
Downloads:
