listbrowser hierarchical mode
mritter0
Post by mritter0 »
I would like an option for listbrowser, using hierarchical mode, to hide all of the lines.
LISTBROWSER_HideHierarchicalLines, TRUE,
Still allow for the 3 custom images.
trixie
Re: listbrowser hierarchical mode
Post by trixie »
The listbrowser can already hide the hierarchical (children) nodes. Use the LBM_HIDECHILDREN method.
The Rear Window blog
mritter0
Post by mritter0 »
I know that; I use it in my program.
I want to not display the black lines that branch down and out for each item. The "directory tree" if you will.
While I am at it: how about different colors (light grey) and more subtle lines (slightly dashed/dots). The black is just so bold.
mritter0 wrote:I want to not display the black lines that branch down and out for each item. The "directory tree" if you will.
GUI Prefs, Gadgets->Classes->ListBrowser->uncheck Connect nodes with lines.
So it is a user choice, not a programmer choice.
mritter0
Post by mritter0 »
It could/should be both. ;)
mritter0
Post by mritter0 »
Not to start a conflict, but in the GUI Prefs->Gadgets->Clicktab there is a checkbox for "Evenly sized tabs". This is also a programmer option CLICKTAB_EvenSize.
So why I can't I have my request be a programmer option? Not everything is covered in the GUI Prefs for every gadget type. As in, Chooser "Cycle symbol style" and "justification" should also be programmable. Programmable in CLICKTAB is the CloseImage and ClosePlacement, but they are not in the GUI Prefs.
It is my program. If I want a certain look I should be able to specify any option and override the GUI Prefs. Else, if I want the defaults, I don't specify anything. Or a flags that says use the default. CLICKTAB_EvenSize, TRUE/FALSE/DEFAULT,
I am not nit-picking, but I do want full control of how my program looks for certain aspects.
The programtical control for Even sized tabs is intended for dynamic tabs whereas the global control is for general tabs in fixed layouts, at least that's how I think of it.
As to full control of the listbrowser look, investigate the render hook.
