New EHCI driver fails on my system
Hypex
Re: New EHCI driver fails on my system
Post by Hypex »
amigaonefan wrote:This differs from OS4.1 update 5, in which I have to disable the internal usb ports or else the system locks up
Does this happen also if the EHCI driver is disabled?
I have disabled my A1 back ports since my USB2 card can work on the back with hot plugging in USB1.x mode fine. But I use my front ports connected to on board USB.
I can use all these ports together, A1 and USB card, fine in USB1.x mode.
amigaonefan
Post by amigaonefan »
I believe so....I'll double check today and let you know for sure if I get time.
Hypex
Post by Hypex »
Try disabling the network driver and test EHCI also.
natman
Post by natman »
I get the same behaviour with EHCI driver. If it's disabled, system doesn't freeze at any moment even using SWAP memory. :D
If EHCI driver is enabled, system freezes in any moment sooner or later. :ugeek:
Hypex
Post by Hypex »
natman wrote:I get the same behaviour with EHCI driver.
What's your A1 and USB hardware?
satiropan
Post by satiropan »
I would like to add my experience with my a1g3se board and onboard usb and nec usb pci card.
with os4.1.6 always updated, I have to disable onboard usb in uboot, then I have to disable uhci driver in kicklayout, so the nec usb card works, but
if I copy big files, such as mp3 or films, from usb keydrive (fat 32 8gig), it freezes, sooner or later.
if I use a usb to lan adapter with the adm chip, belkin f5d5050, I get connection to internet for a while but sooner or later there comes a DSI error, then I have to reboot
If I enable onboard usb, no Nec card, the OS4.1.6 won't open, it freezes at the splash screen
If I use OS4.0 on a different HD, no Nec card and onboard USB enabled, I see a fat32 8gig usb keydrive as non dos
the lan adapter seems to work
more tests in the future
Satiropan
PPA1200 (Poor Portable Amiga 1200): BPPC-160MB,
BVision-CGX4, HD 10GB, slim DVD R/W, Asus VW161D
display, 3COM Lan PC card, OS4.1FE
AmigaOne G3-SE 600MHz, 1GB, Radeon 9200 128DDR,
CS4281 sound card, RTL8029, SiI3114, OS 4.1.6 & OS4.1FE
http://www.oldfab.webs.com
Hypex
Post by Hypex »
satiropan wrote:I would like to add my experience with my a1g3se board and onboard usb and nec usb pci card.
Thanks for your experiences. Yes the SE has more trouble than the µA1 regards to USB! I recommend to disable the EHCI module. This will surely cause trouble as I see it. You can test with it disabled in any case.
