AOS 4.1 FE bug - the shell crashes when iconified
Re: AOS 4.1 FE bug - the shell crashes when iconified
Another test: with KingCON iconifying works fine.
Problem found: missing SYS:System/Shell.info.
Thanks for finding that. Now I'll have to find out whose fault it is if the chain crashes when the icon is missing.
You're welcome.
My wild and OS-ignorant guess goes like this...
Since Snoopy reports no attempt at opening the icon when iconification is requested, it looks like the icon is pre-loaded at initialization; such pre-loading is (rightfully) fault-tolerant, but then, when the moment of iconifying comes, a wrong (NULL?) reference is passed to icon.library, which crashes. Or something vaguely along those lines
Looking at the console code (pretty old now), I can see that your insight is exactly right. It tries to GetDiskObject("ENVARC:Sys/def_Shell") first, then, if that doesn't work, it tries to GetDiskObject ("SYS:System/Shell").
Whatever it gets (or doesn't) is passed to workbench.library as the icon to use to build the AppIcon when iconifying.
I'll have to take advice on this problem.
Ah, good to know! I'll move the icon from SYS:System/ to ENVARC:Sys/, so that I can be unsnapshot, and thus have the icon located at the first free "slot" on the Workbench. Thanks.tonyw wrote:Looking at the console code (pretty old now), I can see that your insight is exactly right. It tries to GetDiskObject("ENVARC:Sys/def_Shell") first, then, if that doesn't work, it tries to GetDiskObject ("SYS:System/Shell").
I think I have seen some programs default to a (very ugly) old, 1.3 style icon for iconification sometimes. Is there maybe such a thing defined internally somewhere (icon.library? workbench.library? or wherever) which could be used as a last resort?tonyw wrote:Looking at the console code (pretty old now), I can see that your insight is exactly right. It tries to GetDiskObject("ENVARC:Sys/def_Shell") first, then, if that doesn't work, it tries to GetDiskObject ("SYS:System/Shell").
Just a thought.
Definitely. Make (some of) the ENVARC:Sys/def_#?.info icons unaccessible and you'll get old-style (3.0?) icons:nbache wrote:I think I have seen some programs default to a (very ugly) old, 1.3 style icon for iconification sometimes. Is there maybe such a thing defined internally somewhere (icon.library? workbench.library? or wherever) which could be used as a last resort?
There are several suitable "def_xxx" icons in ENVARC:Sys/, not including "def_shell" which the console was also looking for. There are "def_iconify" and "def_kingcon" (shudder). I can test to see if one of these is present, but there is still the possibility that none is present - what then?
Currently trying to find out what I have to do to store a default icon within the code...
BZ #9109.
BZ #9109.
I agree. The solution is not to "buy more lottery tickets", but to establish a failsafe last resort.tonyw wrote:There are several suitable "def_xxx" icons in ENVARC:Sys/, not including "def_shell" which the console was also looking for. There are "def_iconify" and "def_kingcon" (shudder). I can test to see if one of these is present, but there is still the possibility that none is present - what then?
Which is what
- will achieve.Currently trying to find out what I have to do to store a default icon within the code...
