I have find some bugs in AmigaOS4.1 Final Edition for Pegasos 2.
Hardware:
Pegasos 2, 1Ghz, 1024MB RAM
Radeon 9250 AGP graphics card
CD0: CD-ROM SAMSUNG SH-152A
CD1: CDDVDW TSSTCorp SH-S202H
CD2: CD-R/RW TSSTCorp TS-H292A
Harddrive: WDC WD80 WD-WMAM9DST (80Gb)
I use FFS (DOS\07) filesystem on all (8) partitions on the harddrive (peg2ide.device).
Here is the bugs I have found so far: (ref to included pictures)
1. Time prefs can't open battclock.resource (time can't be saved, and must be adjusted every time the computer starts up) (picture 1)
2. PartitionWizard can't find any hard disk partitions (picture 2).
3. FormatCDRW can't find any devices (picture 3).
4. WBStartup Preferences, click on Information, the information window open but shows all wrong (picture 4).
5. Screenmode preferences, do not show the name of the graphicsdriver in screenmode names, only shows "Board 0:" (picture 5).
Re: AmigaOS4.1 Final Edition
Continuing, two pictures more...
- salass00
Can you check if you have a file "battclock.resource.kmod" in your Kickstart directory and post the contents of your Kicklayout file?Nisse321 wrote: 1. Time prefs can't open battclock.resource (time can't be saved, and must be adjusted every time the computer starts up) (picture 1)
This problem was reported also by chris here:2. PartitionWizard can't find any hard disk partitions (picture 2).
http://forum.hyperion-entertainment.biz ... =14&t=2788
This problem is already known about and fixed. Unfortunately the fix was slightly too late to make it onto the FE release CDs.4. WBStartup Preferences, click on Information, the information window open but shows all wrong (picture 4).
AFAIK this is how it should be. At least it's what I'm getting as well on both my FE and Beta installs.5. Screenmode preferences, do not show the name of the graphicsdriver in screenmode names, only shows "Board 0:" (picture 5).
In classic days when i have a1200/mediator/voodoo3, i also have "board 0" , then, later at some point on os4 i realise that instead of kind-of-cryptic Board 0: i have name of card instead, what is good. And now, its again back to Board 0: seems. Radeonxxx instead of Board 0 was for sure better and more understandable. Dunno if it done specially back,or just some side-effect of merge of graphics libs and can be fixed. Anyway, have name of board instead of Board:0 in screenmode prefs is better, imho.AFAIK this is how it should be. At least it's what I'm getting as well on both my FE and Beta installs.
If you switch to the Monitor tab in the ScreenMode prefs you see the name of the board. However, if you have 2 graphics boards installed, I don't know how you would know which board name is board:0 or Board:1. It seems like it could be confusing for dual board users.kas1e wrote: Anyway, have name of board instead of Board:0 in screenmode prefs is better, imho.
Edit 2015-01-17:salass00 wrote:Nisse321 wrote: 1. Time prefs can't open battclock.resource (time can't be saved, and must be adjusted every time the computer starts up) (picture 1)Can you check if you have a file "battclock.resource.kmod" in your Kickstart directory and post the contents of your Kicklayout file?
FormatCDRW needs CDRW/DVDRW drivers (SYS:Storage/DOSDrivers) to be activated to work, I tested this and FormatCDRW works now.
I have battclock.resource.kmod v53.1 (2011-11-14) in kickstart.
When I replaced battclock.resource.kmod with v51.2 (2005-01-23) (update 6) then Time prefs can open battclock.resource.
Including my kicklayout file.
; $VER: Kicklayout-PegasosII 53.9 (12.10.2014)
; Kernel configuration for the Pegasos II
; This file describes how the "Kickstart" image should look like,
; i.e. it describes which modules should be pre-loaded and available
; at boot time.
; Format:
; The file lists one or more configurations.
; Each configuration starts with the LABEL keyword, followed by the
; name of the configuration. The name can be used to specify the
; configuration in the bootloader tool (see Documentation/kernel/
; bootloader.txt). Note that empty lines end one configuration and
; start the next, which means that you must be careful not to leave
; an empty line anywhere unless you are defining multiple configurations.
; Each configuration must have exactly one line with the EXEC keyword.
; This specifies the filename of the main kernel to use. This kernel is
; the absolute minimum required to boot. It contains, among other things,
; exec.library.
; The following lines define additional modules to be loaded into the
; kickstart image. Each of these lines starts with the MODULE keyword
; followed by the filename of the module.
; Configuration name
LABEL AmigaOS_4.1_Final_Edition
; Exec name
EXEC Kickstart/loader.of
; PPC native modules
MODULE Kickstart/kernel
MODULE Kickstart/FastFileSystem
MODULE Kickstart/SmartFilesystem
MODULE Kickstart/JXFileSystem
MODULE Kickstart/peg2ide.device.kmod
MODULE Kickstart/battclock.resource.kmod
MODULE Kickstart/bootmenu.kmod
MODULE Kickstart/bootimage
MODULE Kickstart/CDFileSystem
MODULE Kickstart/con-handler.kmod
MODULE Kickstart/console.device.kmod
MODULE Kickstart/diskboot.kmod
MODULE Kickstart/diskboot.config
MODULE Kickstart/diskcache.library.kmod
MODULE Kickstart/dos.library.kmod
MODULE Kickstart/elf.library.kmod
MODULE Kickstart/env-handler.kmod
MODULE Kickstart/FileSystem.resource.kmod
MODULE Kickstart/gadtools.library.kmod
MODULE Kickstart/gameport.device.kmod
MODULE Kickstart/graphics.library.kmod
MODULE Kickstart/hunk.library.kmod
MODULE Kickstart/input.device.kmod
MODULE Kickstart/intuition.library.kmod
MODULE Kickstart/it8212ide.device.kmod
MODULE Kickstart/keyboard.device.kmod
MODULE Kickstart/keymap.library.kmod
MODULE Kickstart/lsi53c8xx.device.kmod
MODULE Kickstart/newlib.library.kmod
MODULE Kickstart/nonvolatile.library.kmod
MODULE Kickstart/nvram.config
;MODULE Kickstart/nvram_nodma.config
MODULE Kickstart/ps2.resource.kmod
MODULE Kickstart/ram-handler.kmod
MODULE Kickstart/ramdrive.device.kmod
MODULE Kickstart/ramlib.kmod
MODULE Kickstart/shell.kmod
MODULE Kickstart/sii0680ide.device.kmod
MODULE Kickstart/sii3112ide.device.kmod
MODULE Kickstart/sii3114ide.device.kmod
MODULE Kickstart/sii3512ide.device.kmod
MODULE Kickstart/strap.kmod
MODULE Kickstart/timer.device.kmod
MODULE Kickstart/PCIGraphics.card
MODULE Kickstart/ATIRadeon.chip
MODULE Kickstart/3dfxVoodoo.chip
MODULE Kickstart/petunia.library.kmod
MODULE Kickstart/usbresource.library
MODULE Kickstart/usbsys.device
MODULE Kickstart/hub.usbfd
MODULE Kickstart/bootmouse.usbfd
MODULE Kickstart/bootkeyboard.usbfd
MODULE Kickstart/massstorage.usbfd
MODULE Kickstart/uhci.usbhcd
MODULE Kickstart/ohci.usbhcd
MODULE Kickstart/ehci.usbhcd
Same issues here on Pegasos II... and here's another one... not sure if this has already been reported (I haven't seen it) but WBStartup prefs shows progress of all of the wbstartup configured programs when you select "show progress window" even those added but *not* selected to start... it should only show those selected.. right?
Thank you,
Dragster
Thank you,
Dragster
I have the same issues on my Peg II. I checked battclock.resource on OS 4.1u6 and there is no problem.
Other solution for this can by yfacts (put it in WBStartup), it will "take" time from Internet.
Quoting myself... this is not a bug, current behavior is the way it's intended to be.Dragster wrote:Same issues here on Pegasos II... and here's another one... not sure if this has already been reported (I haven't seen it) but WBStartup prefs shows progress of all of the wbstartup configured programs when you select "show progress window" even those added but *not* selected to start... it should only show those selected.. right?
Thank you,
Dragster
Dragster
kate.libby
Good Morning!
The Solution for Error with battclock.resource.kmod is simple: Copy the 4.1.6 Version of battclock.resource.kmod in the FE Folder and Time-Prefs works without Problems.
Pegasos II with 1GHz / 1GB Ram / 500GB HDD with MorphOS 3.6 / AmigaOS 4.1.6 & FE / Radeon 9000 Pro
