DiskImage (solved)
Re: DiskImage (solved)
sundown wrote:Edit: email sent
Thanks, got it. I'll check whether it fails for me too, and if so, try to work out why.
Status so far:
Sundown's file makes the crash also on my system consistantly.
I've made a couple of crashlogs, and am now trying (in spare moments) to isolate which setting(s?) create the problem.
Will report back ...
sundown
Post by sundown »
nbache wrote:Status so far:
Thanks for the update, I never did find any setting to cause the crash, was just easier to delete prefs & re-create it.
Ken
