DVPlayer crashes
Hypex
DVPlayer crashes
Post by Hypex »
Hello. Back again. :-)
I have collected two seperate reports for DvPlayer crashes. I understand that DvPlayer is a third party shareware utility but as DvPlayer SE is included with the OS and this is what I am using thought I should at least report it here.
Here is the outlines:
1.) Crashes while trying open a file while an MPEG2 stream was playing.
I was playing off a DVD and tried to open a file. It crashed. Of course it makes sense to stop it first but I expected DvPlayer to halt it. The result:
Crash log for task "DvPlayer AsyncIO Task"
Generated by GrimReaper 53.2
Crash occured in module dos.library.kmod at address 0x019043E4
Register dump:
0: 019043D8 6F8CAF10 00000000 00001810 74AE5D08 02092AB4 01913F64 6FF564D0
8: 46490000 00000000 00000020 021A6876 00000020 FFDFBA45 FFFFFFFF FFFFFFFF
16: EFB60E70 80000000 6F8CAF4C 6F8CAF48 6F8CAF50 5A910000 00010000 6F8ED000
24: 5A910000 02250000 000000CD 999ED000 02250000 5A910000 02250000 74AE5CC0
0: nan 2.122e-314 -2.41908e-312 0
4: 0 271.8 239.8 -2.18566e-312
8: -2.48274e-312 -2.14322e-312 -2.16444e-312 -2.3342e-312
12: 0 -2.27054e-312 -9.39965e+213 1.28081e-173
16: -1.84586e-19 -1.30504e-54 -2.24597e+307 7.01088e-14
20: -2.5495e-26 -1.01756e+285 0.000963684 -3.05336e+220
24: 7.00551e+280 -0.496074 -2.47598e-119 -5.4387e-48
28: 0.00170485 5.6884e-18 -4.32609e-19 4.55417e-159
Machine State (msr) : 0x0000F030
Condition (cr) : 0x33E35335
Instruction Pointer (ip) : 0x019043E4
Xtended Exception (xer) : 0xC000C646
Count (ctr) : 0x0181B648
Link (lr) : 0x019043D8
DSI Status (dsisr) : 0x40000000
Data Address (dar) : 0x74AE5D08
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x019043E4 belongs to module "dos.library.kmod" (HUNK/Kickstart)
Stack trace:
native kernel module dos.library.kmod+0x00004564
module DvPlayer at 0x7F399EDC (section 5 @ 0x13EBC)
native kernel module dos.library.kmod+0x0001b524
native kernel module kernel+0x0003cd50
native kernel module kernel+0x0003cdd0
PPC disassembly:
019043dc: 419e0018 beq- cr7,0x19043F4
019043e0: 3d004649 lis r8,17993
*019043e4: 809f0048 lwz r4,72(r31)
019043e8: 61034c45 ori r3,r8,19525
019043ec: 7c841800 cmpw cr1,r4,r3
2. Crashes while playing mp3 file.
This is very easy to reproduce. Just load an mp3 file and start playing. After a while it will crash. It is recoverable and the music can go on. :-)
Note that I did have some 320Kbps mp3s but I don't know if that matters. Result:
Crash log for task "DvPlayer"
Crash occured in module DvPlayer at address 0x7DF925A4
Register dump:
0: 4EC65000 50018C00 5B402290 00000000 4EF30000 00000000 FFFFE712 4E84A208
8: 4E84A028 4EC67580 00000000 00000000 00000078 4EF31FFC 4EF30000 4EF2C280
16: 50C8E274 50C8E248 4EF30000 50C8E2A0 4EF2C280 4EF30000 4EF30000 00000000
24: 4EF30000 4E82E008 4EF30000 4EF30000 0000001A 000003C0 000000F0 000001E0
0: nan -0.779055 3.83476e-17 1.95132e+43
4: 3.96134e-310 1.80416e-314 4.48378e-311 3.96007e-310
8: 0.805402 -1.14424e-17 -0.779055 0.16941
12: 26.5917 nan -3.26984e-96 1.01803e-16
16: -1.84586e-19 -7.07464e-74 -5.48332e+303 7.0997e-14
20: -2.23648e-26 -1.55268e+280 -0.42993 -1.31142e+230
24: 255 2.14748e+09 1.52588e-05 4.5036e+15
28: 65536 4.5036e+15 65536 5.40003
FPSCR (Floating Point Status and Control Register): 0xA2028100
Condition (cr) : 0x42002044
Instruction Pointer (ip) : 0x7DF925A4
Xtended Exception (xer) : 0x00000000
Count (ctr) : 0x00000000
Link (lr) : 0x7DF9246C
Data Address (dar) : 0x4EC67582
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x7DF925A4 belongs to module "DvPlayer" (HUNK/Kickstart)
Stack trace:
module DvPlayer at 0x7DF925A4 (section 5 @ 0x16584)
module DvPlayer at 0x7DF92B44 (section 5 @ 0x16B24)
module DvPlayer at 0x7DF82ACC (section 5 @ 0x6AAC)
module DvPlayer at 0x7DF83088 (section 5 @ 0x7068)
native kernel module newlib.library.kmod+0x00001f44
native kernel module newlib.library.kmod+0x00002bd8
native kernel module newlib.library.kmod+0x00002d54
_start()+0x170 (section 1 @ 0x170)
PPC disassembly:
7df9259c: 8124a2a0 lwz r9,-23904(r4)
7df925a0: 7f9f5000 cmpw cr7,r31,r10
*7df925a4: a9690002 lha r11,2(r9)
7df925a8: a8090000 lha r0,0(r9)
7df925ac: 409d0084 ble- cr7,0x7DF92630
Re: DVPlayer crashes
You are right in saying that it's a third party contribution so you would be well advised to send them to the author as well.
Makeing a note of them here does no harm I suppose but there no guarantee any action will be taken on them, or that they will be seen by the relavant person.
Rigo
Post by Rigo »
In actual fact, it doesn't look like Stephen Felner is a member here, so he'll never see any bug reports for DvPlayer. Send them to him directly.
Simon
Stephen Robinson
Post by Stephen Robinson »
Just in case you've not noticed, DvPlayer version 0.76 has beeen Released
http://dvplayer.amigarevolution.com/
tommysammy
Post by tommysammy »
Stephen Robinson wrote:Just in case you've not noticed, DvPlayer version 0.76 has beeen Released
And works really good on my classic :D
Mrodfr
Post by Mrodfr »
Hello,
Have you tried to reproduce your problem with dvdvcd.plugin 51.2 (from the original DVplayer registered version) ?
I have this kind of crash Number1 with dvdvcb.plugin 51.4. When I insert A DVD and use open DVD/CD before completely recognized by the system.
ssolie
Post by ssolie »
Hypex wrote:I have collected two seperate reports for DvPlayer crashes.
I think your time is better spent emailing the author directly instead of hoping he reads it in a web forum.
Hypex
Post by Hypex »
Mrodfr wrote:Have you tried to reproduce your problem with dvdvcd.plugin 51.2 (from the original DVplayer registered version) ?
No I am using dvdvcd.plugin 51.4. I don't have is registered so am using the SE version.
