where am I supposed to get information to W3D_SetTextureBlend?
In the latest docs it says
"This function controls multitexturing. Very complex stuff. Please write a better autodoc for me."
plus
"A complete description of this function with examples can be found in the SDK."
Okay, either it is hidden quite well or there simply isn't even the promised example that explains everything.
So, what to do?
Daniel
p.s.:
actually the whole Warp3D doc needs massive improvement.
For instance, there isn't mentioned which states default to which values.
Or info like "is it valid to call SetTexEnv with a null-tex if GLOBALTEXENV is enabled?" would be interesting too.
Then there are many obviously outdated statements like "tmu - must be zero" for W3D_BindTexture.
Or W3D_DrawElements "There are three possible values W3D_INDEX_UBYTE, W3D_INDEX_USHORT and W3D_INDEX_ULONG.". Only that there is no such define as W3D_INDEX_USHORT, should be _UWORD.
etc., etc., etc.
