__USE_INLINE__
JosDuchIt
__USE_INLINE__
Post by JosDuchIt »
The OS3 BOOPSI example RKMButClass.c, i worked on,now compiles and works under OS4
I am now trying to get rid of pointer warnings
I do use
#define __USE_INLINE__
So in 'main' i have
struct Gadget *integer, *but;
if (integer = (struct Gadget *)NewObject(NULL,
"strgclass",
GA_ID, 1L,
TAG_END))
if (but = (struct Gadget *)NewObject(rkmbutcl,
and at cleanup:
DisposeObject(but);
DisposeObject(integer);
I get the warning: passing argument 2 of 'IIntuition->DisposeObject' from incompatible pointer type
for both lines
Looking into the file RKMButClass.e
produced using gcc's -E option
i find the same declarations for but and integer
and the follosing 'Dispose' lines
IIntuition->DisposeObject((but));
IIntuition->DisposeObject((integer));
In the autodoc i found
intuition.library/DisposeObject intuition.library/DisposeObject
void DisposeObject(Object *obj);
INPUTS
obj - abstract pointer to a BOOPSI object returned by NewObject().
NAME
So i tried a cast
DisposeObject((struct Object *)but);
DisposeObject((struct Object *)integer);
Those lines were transformed in the .e file to
IIntuition->DisposeObject(((struct Object *)but));
IIntuition->DisposeObject(((struct Object *)integer));
but i still have exactly the same warnings.
Is it possible at all using the __USE_INLINE__ define and corresponding macro's to avoid those warnings?
trixie
Re: __USE_INLINE__
Post by trixie »
There is no "struct Object", there is only Object!
As of the latest OS4 SDK, all BOOPSI gadgets and images are to be declared as a pointer to Object, not struct Gadget or Image, respectively. So try something like this:
Object *integer, *but;
if (integer = NewObject(NULL,
"strgclass",
GA_ID, 1L,
TAG_END))
if (but = NewObject(rkmbutcl,
If a specific function - like SetGadgetAttrs() - expects a pointer to struct Gadget (instead of an Object), you need to cast:
SetGadgetAttrs( (struct Gadget *) but, window, NULL, ... TAG_END);
The Rear Window blog
JosDuchIt
Re: __USE_INLINE__
Post by JosDuchIt »
Thanks Trixie,
The source now compiles without warnings.
I uploaded it here
http://users.online.be/AD/C_Boopsi_RKMButClass.c
I had still to do some more adaptions:
make more explicit declarations:
Object *integero, *buto;
struct Message *msgm;
struct IntuiMessage *msgi;
where
but = (struct Gadget *)buto;
integer = (struct Gadget *)integero;
and also
with appropriate cast :
msgi = (struct IntuiMessage *)msgm;
I also made use of the general layout you used in your Reaction example
trixie
Re: __USE_INLINE__
Post by trixie »
@JosDuchIt
Thanks. The example might entice me to write a custom ReAction class - something I wanted to try out for quite some time.
