The ISO linked below works with the Sam460ex and Radeon PCIE video cards up to Radeon HD 6000 series .
It has a 3.13-rc7 kernel. Was the last Sam460ex one I did before my Sam460ex was destroyed.
Tomorrow ,27 Feb 2014, Is the release date for Lubuntu 14.04 beta 1 milestone so good time to get onboard.
Download opera browser PPC archive.
Open a Terminal (XTerm) on your linux/ubuntu desktop and CD where file is downloaded, unarchive it with tar -zxvf , CD into the new directory and then type sudo ./install, follow installation (aka press RETURN key when prompted until finishes). Run it from shell (opera).
Same error.
Firefox 28 was working ok for me to up to 17th March.
I tend to be aggressive with my updating and some updated components on 18th March led to the problem.
I will either wait it out till beta 2 in about 9 days or so or reinstall using an installer ISO from 17March or before .
Spectre660 wrote:Something has broken the latest firefox version.
Spectre660 wrote:Same error.
Could you reinstall the Firefox browser, please? Firefox 28 runs very well on my Lubuntu 14.04 on my Sam440ep Flex and on my A1-X1000. It also works well on Lubuntu 12.04.4.
I tried to reinstall firefox but it resulted in the same issue.
I will do a reinstall of Lubuntu 14.04 at some point but want to wait for the beta-2 ISO
Reinstalled Lubuntu 14.04 form the 17th March daily iso and updated some 55 mb after the install.
Firefox 28 is working on the fresh installation.
Spectre660 wrote:Reinstalled Lubuntu 14.04 form the 17th March daily iso and updated some 55 mb after the install.
*** Lubuntu: Testers needed for PowerPC 14.04 ***
Quote by rsavage:
Release time soon, so why not help out with the testing? A PowerPC ISO will only be released if it is tested and passes all tests. This is a VERY time consuming process, so if you are able to help out I'm sure it would be greatly appreciated by the lubuntu-qa team. Lots of info about testing in the FAQ and Lubuntu wikis.
Don't assume somebody else is going to do it for you, otherwise you might be in for a shock (kubuntu users?).
I've updated the "Known Issues" page with the current bugs from the tracker. Most of them are old (and not necessarily powerpc specific). I think there are workarounds for most, although I've yet to try the one for the live installer.
Please don't spam this thread with waffle. Comments in this thread mean nothing. The release team are only interested in official bug reports and official tracker testing results. Remember to confirm any existing bugs as this adds 'heat' to the bug.
Please also update the PowerPC Known Issues page with any new bugs/workarounds as it makes life so much easier for the next person.
If you have a problem that you want help with then RAISE A NEW THREAD.
